Home » Archived » Test and Performance Tools Platform (TPTP) » **** Build of configuration (Exec error:Launching failed) in Standard Mode
**** Build of configuration (Exec error:Launching failed) in Standard Mode [message #134551] Thu, 21 August 2008 05:28 Go to next message
I follow sequences in AGR to create test suite:
1) Create Java project.
2) Import Hello class with print "Hello!".
3) Select project and build.
After that, I run test suite in Quick Mode is ok but error message
displays when running in Standard Mode as following:
**** Build of configuration xxx for project xxx ****
Thanks for your consideration,
Phong
Re: **** Build of configuration (Exec error:Launching failed) in Standard Mode [message #134606 is a reply to message #134551] Thu, 21 August 2008 06:47 Go to previous message
Hi Phong,
When running in Quick Mode, you are running the AGR test case in the
local workbench, as it is configured (e.g. open perspectives/views, etc.).
Using Standard Mode, it is running the test in a new workbench instance,
with the default configuration. Sometimes, your test may be expecting
certain perspectives/views to be open and there are not.
Paul
"Phong Ho" <phongho@gmail.com> wrote in message
news:1d17c88894f5a3fbc1a2edab9370ab6e$1@www.eclipse.org...
> 1) Create Java project. 2) Import Hello class with print "Hello!".
> following: -------------------------------------------------------
> Phong
Previous Topic:How to run a recorded AutoGUI macro inside a JUnit test suite?
Next Topic:Error to start my first profiling project at a Linux box
Current Time: Fri Jul 25 01:58:46 EDT 2025
Powered by FUDForum. Page generated in 0.03336 seconds
