Home » Archived » Visual Editor (VE) » Where is the SWT Components?
Where is the SWT Components? [message #134290] Tue, 19 December 2006 22:14 Go to next message
Originally posted by: neo_online_ca.yahoo.ca
I just installed VE 1.2. But I cannot find "SWT Components" on the Palette.
I can see "Swing Components","Swing Containers","Swing Menus", and "AWT
Contols. But "SWT Components" is no where to be found. So how to I create a
GUI using SWT here?
Am I missing something here?
Re: Where is the SWT Components? [message #134489 is a reply to message #134290] Tue, 02 January 2007 19:11 Go to previous message
You have to add the SWT library to the classpath. The palette can only
show classes that are in the current classpath.
The easiest way to get the classpath set up is to use the New Visual
Class wizard, select the SWT style from the tree, and then select the
type of SWT class you want to generate.
> GUI using SWT here?
Rich Kulp
Re: Where is the SWT Components? [message #614964 is a reply to message #134290] Tue, 02 January 2007 19:11 Go to previous message
> GUI using SWT here?
Rich Kulp
Previous Topic:Extending the VE palete
Next Topic:Add component more than once
Current Time: Fri Jul 18 06:17:49 EDT 2025
Powered by FUDForum. Page generated in 0.27914 seconds
