Quick and Standard mode [message #134444] |
Tue, 19 August 2008 10:25  |
Originally posted by: jakrezni.cz.ibm.com
IŽve created some Test Cases and when I simply re-play them, they work and
no error occur. But when I run them in a standard mode, it fails... before
IŽll write some more information why it fails, IŽd like to ask someone: Is
there any difference between these modes?
Thanks a lot, Jakub
Re: Quick and Standard mode [message #134593 is a reply to message #134507] |
Thu, 21 August 2008 06:47   |
Hi Jakub,
When running in Quick Mode, you are running the AGR test case in the
local workbench, as it is configured (e.g. open perspectives/views, etc.).
Using Standard Mode, it is running the test in a new workbench instance,
with the default configuration. Sometimes, your test may be expecting
certain perspectives/views to be open and there are not.
Paul
"Jakub Reznicek" <jakrezni@cz.ibm.com> wrote in message
news:7fd279b76abfc9bd91ca1bec89566df3$1@www.eclipse.org...
> thanks for your answer...I think the problem is with the items I test...
> For example I right click on a XML file and "do something" with that (for
> example open its properties) and when I run it in standard mode, it can
Re: Quick and Standard mode [message #134747 is a reply to message #134634] |
Fri, 22 August 2008 06:45  |
When you record, just make sure that you start with the same
perspective/views (note, no files would exist in the navigator) that would
be available when Eclipse first starts.
Paul
news:c6d73335236650dadf598d29e263169d$1@www.eclipse.org...
> Hi Paul,
> thanks a lot for your answer. It makes sense...so, is it possible to set
> it up in TPTP configuration or do I have to do it in Eclipse itself (it
> wouldn
FUDForum. Page generated in 0.24918 seconds
