Home » Eclipse Projects » Eclipse Platform » Eclipse 4 editor tab position
Eclipse 4 editor tab position [message #988927] Mon, 03 December 2012 14:58 Go to next message
Simple question: Can I get the tabs on the BOTTOM of the editor window
with Eclipse 4, or will I be forced to re-train my brain to put up with
them at the top?
Some may think this is a trivial issue, but I assure you it's not.
Anyone who has done research into usability studies will know this.
Next step: Is there a way to get the 'up' and 'down' 'arrows' for
scrollbars next to each other (at the bottom/right)?
If the answer to all this is "download the full Eclipse source and hack
the XWT code"...
Re: Eclipse 4 editor tab position [message #988992 is a reply to message #988927] Tue, 04 December 2012 03:08 Go to previous messageGo to next message
Am 03.12.12 20:58, schrieb Jamie Cooper:
> them at the top?
Ideally it would be controlled through CSS but I could not find it
listed at http://wiki.eclipse.org/E4/CSS/SWT_Mapping#Widget:_CTabFolder
so please file a bugzilla.
No those are toolkit specific and can be changed.
Tom
Re: Eclipse 4 editor tab position [message #1342069 is a reply to message #988992] Thu, 08 May 2014 15:48 Go to previous messageGo to next message
Did you find a way to do it?
Using css spy and jeeeyul I came up with this piece of css, but it messes the whole interface, so it is unusable. Maybe I did something wrong. I just added to custom css
#org-eclipse-e4-primaryDataStack.MPartStack {
swt-tab-position: bottom;
Re: Eclipse 4 editor tab position [message #1343767 is a reply to message #1342069] Fri, 09 May 2014 08:52 Go to previous messageGo to next message
Try
.EditorStack {
or
#org-eclipse-e4-primaryDataStack {
Re: Eclipse 4 editor tab position [message #1344421 is a reply to message #1343767] Fri, 09 May 2014 15:20 Go to previous messageGo to next message
Thank you very much.
That works but only if I use/edit a normal theme css and not jeeeyul.
Re: Eclipse 4 editor tab position [message #1361059 is a reply to message #1344421] Fri, 16 May 2014 22:52 Go to previous message
Well, Jeeeyul's Eclipse Themes(2.1.6) is not supporting bottom tab because it uses its own renderer.
You're able to customize the style via Jeeeyul's Themes settings->Custom CSS, and it causes UnsupportedOperationException.
>Caused by: java.lang.UnsupportedOperationException
> at net.jeeeyul.eclipse.themes.rendering.JeeeyulsTabRenderer.computeTrim(JeeeyulsTabRenderer.java:269)
because
>if(tabFolder.onBottom) {
> throw new UnsupportedOperationException
You must request the feature against Jeeeyul's Eclipse Themes apparently.
Previous Topic:Adding markers synchronously to file
Next Topic:How to write a plugin register mechanism, that can register own icons, commands, handlers etc.
Current Time: Fri Jul 25 22:15:50 EDT 2025
Powered by FUDForum. Page generated in 0.28559 seconds
