Unable to Start Eclipse ( New to Eclipse) [message #133258] |
Sun, 11 January 2004 21:22  |
Originally posted by: yvramj.yahoo.com
I am not able to start eclipse. I loaded it on Windows 98. I have Java
j2sdk1.4.2_03 on my mechine. I am getting the following error.
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Jan 11, 2004 19:52:28.410
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:437)
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Please let me know where I am going wrong.
Ram.
Re: Unable to Start Eclipse ( New to Eclipse) [message #136923 is a reply to message #134957] |
Fri, 23 January 2004 22:26  |
Ram wrote:
I got one of my old projects into Eclipse and trying run it.
I am getting errors while bulding the project like
" The declared package does not match the expected package COM.EMP.BEAN ".
I am not sure these error may be because of JRE settings. I went thru the
manual and my settings are good. When I did Window--> preferences-->
Java-->
installed JREs, it is showing the c:\J2SDK1.4.2_03 as the standard VM. I
am not sure if I need any more JREs to be installed. Can any one please
help me
what would be the wrong ?
Ram.
> Pawel Silberring wrote:
> > Ram wrote:
> > > Markus Keller wrote:
> > >>Ram wrote:
> > >>>My JAVA is in C:j2sdk 1.4.2_03 and Eclipse in C:Eclipseeclipse.exe.
> > >>>I tried to start eclipse as
> > >>>C:Eclipseeclipse.exe -VM C:j2sdk1.4.2_03jrebinjavaw.exe
> > >>>and also as
> > >>>C:Eclipseeclipse.exe -VM C:j2sdk1.4.2_03binjavaw.exe
> > >>>It is still giving the same error.
> > >>Have you tried the correct spelling (lowercase "-vm", not "-VM")?
> > >>Markus
> > > I deleted Eclipse and loaded it again. But still I am getting the same
> > > error.
> > > If I try to start Eclipse with out -vm command it is giving the error
> > > " could not open 'C:Program FilesJavaj2re1.4.2_03libi386jvm.cfg ".
> > > If I try to start with vm like " C:Eclipseeclipse.exe -vm
> > > c:j2sdk1.4.2_03binjavaw.exe " it is writing error to log file. It not
> > > finding JVM in correct location. JVM is in
> > > C:j2sdk1.4.2_03jrelibjvm.cfg. I don't know where to make the change to
> > > look there. Please help me.
> > > Thanks,
> > > Ram.
> > Hi Ram,
> > I had exactly the same problem with exactly the same versions (and
> > beeing a newbe too). In my case, checking the 'use folder names' box
> > during unzip soved the problem. Hope it works for you too.
> > Regards
> > Pawel
> Excellent Powel..! It worked great. Thank for your help.
> Thank you all for your suggestions.
> Ram.
FUDForum. Page generated in 0.05095 seconds
