Home » Eclipse Projects » Rich Client Platform (RCP) » How to add build ID in about dialog.(How to add build ID in about dialog.)
How to add build ID in about dialog. [message #1338542] Wed, 07 May 2014 05:04 Go to next message
I'm working on RCP application. I'm using tycho to build product.
I want to add content of About Dialog, currently I'm writing it manually by editing product file under Branding tab.
Is there is any other way to add build ID for my application in about dialog.?
index.php/fa/18028/0/
  • Attachment: Untitled.png
    (Size: 57.18KB, Downloaded 1770 times)
Re: How to add build ID in about dialog. [message #1346571 is a reply to message #1338542] Sat, 10 May 2014 13:36 Go to previous messageGo to next message
We also use Tycho to build our RCP application, and our dialog text is updated automatically on each build.
To do this our text is externalised in a '.properties' file, and this file is updated using the standard Maven filtering mechanisms.
Re: How to add build ID in about dialog. [message #1352190 is a reply to message #1346571] Tue, 13 May 2014 06:45 Go to previous message
Please follow the following Steps to generate Build-ID Automatically form Tycho:
1. In your plugin.xml which have org.eclipse.core.runtime.products Extension add or replace following properties.
<property name="aboutText" value="%productBlurb"/>
2. In same plugin open MANIFEST.MF and add following lines.
Bundle-Localization: plugin
This allows you to use plugin.properties
3. Create or open your plugin.properties and add following add your about dialog as below.
productBlurb=Eclipse Platform\n\
\n\
Version: {1}\n\
Build id: {0}\n\
\n\
(c) Copyright Eclipse contributors and others 2000, 2014. \
..... your thing\n
4. now create a about.mappings file if you already have change it like below.
0=${buildId}
1=${releaseName}
5. now open your pom file and add below settings.
<properties>
    <maven.build.timestamp.format>yyyyMMdd-HHmm</maven.build.timestamp.format>
    <buildTimestamp>${maven.build.timestamp}</buildTimestamp>
    <buildId>${buildTimestamp}</buildId>
    <releaseName>5.0.0 RC0</releaseName>
</properties>
<plugins>
  <plugin>
    <groupId>org.apache.maven.plugins</groupId>
    <artifactId>maven-resources-plugin</artifactId>
    <version>2.6</version>
    <executions>
      <execution>
        <id>process-about.mappings</id>
        <phase>prepare-package</phase>
        <configuration>
          <outputDirectory>${project.build.directory}</outputDirectory>
          <overwrite>true</overwrite>
          <resources>
            <resource>
              <directory>${basedir}</directory>
              <includes>
                <include>about.mappings</include>
              </includes>
              <filtering>true</filtering>
            </resource>
          </resources>
        </configuration>
        <goals>
          <goal>copy-resources</goal>
        </goals>
      </execution>
    </executions>
  </plugin>
  <plugin>
    <groupId>org.eclipse.tycho</groupId>
    <artifactId>tycho-packaging-plugin</artifactId>
    <version>${tycho.version}</version>
    <configuration>
      <additionalFileSets>
        <fileSet>
          <directory>${project.build.directory}</directory>
          <includes>
          </includes>
        </fileSet>
      </additionalFileSets>
    </configuration>
  </plugin>
</plugins>
6. run the build now you will get product's about dialog with automatic generated Build-ID.
Previous Topic:Why is bundeling prefered
Next Topic:MathJax is slow in eclipse product
Current Time: Thu Nov 06 12:22:59 EST 2025
Powered by FUDForum. Page generated in 0.03996 seconds
