Another case of VE not showing up after installation [message #133759] |
Fri, 01 December 2006 10:48  |
Originally posted by: kcrews.wabansoftware.com
I'm having the same problem that several others have had with VE not being
visible in Eclipse in 3.2. I'm running on XP Pro SP2. I've tried updating
all my features but it hasn't helped. The error log does not show any
errors from Eclipse startup. Although I'm currently interested in getting
VE to work, in general, how does one debug installation problems like this?
I'm attaching a jpg screenshot of my product configuration dialog.
Re: Another case of VE not showing up after installation [message #133923 is a reply to message #133912] |
Mon, 04 December 2006 17:52  |
Don't do -clean if you can help it. This is only for when updating
during development OUTSIDE of the update manager. If you use the update
manager do not do -clean.
Keith Crews wrote:
> I think the problems were:
> 1) Find updates for installed features was not finding graphical editing
> framework 3.2.1.v20060921. The callisto update does include this version.
> 2) After doing the callisto install, I had to run eclipse -clean to get it
> to work.
> So I tried reverting my configuration to the pre-callisto state, uninstalled
> the now disabled gef 3.2.1, and updated from callisto again, this time just
> picking gef 3.2.1 to install. I then ran eclipse -clean for good luck, and
> ve is now working.
> Thanks for your help.
Rich Kulp
Re: Another case of VE not showing up after installation [message #614829 is a reply to message #133759] |
Fri, 01 December 2006 13:59  |
What do you mean by not showing up?
If you clicked on a java file and did popup menu->Open With-> Does the
Visual Editor show up in that list?
Rich Kulp
Re: Another case of VE not showing up after installation [message #614830 is a reply to message #133778] |
Fri, 01 December 2006 14:44  |
No, it does not show up in the context menu. That's what I meant by not
being visible Also, I am not given the option of creating a new visual
class from the File->New menu. Sorry for the lack of specificity. The only
place I see any evidence of the visual editor is in help. So at least the
help for ve got installed properly. I tried creating a new java project
just in case there was something weird about the configuration of my
existing projects, but that didn't help, either. There was still no option
to create a new visual class.
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:ekpu1o$7ao$1@utils.eclipse.org...
>> being visible in Eclipse in 3.2. I'm running on XP Pro SP2. I've tried
>> updating all my features but it hasn't helped. The error log does not
>> show any errors from Eclipse startup. Although I'm currently interested
>> in getting VE to work, in general, how does one debug installation
>> problems like this?
> Rich Kulp
Re: Another case of VE not showing up after installation [message #614831 is a reply to message #133790] |
Fri, 01 December 2006 15:14  |
How did you install it? What did version of Eclipse SDK did you install
into?
>>> problems like this?
>> Thanks,
>> Rich Kulp
Rich Kulp
Re: Another case of VE not showing up after installation [message #614832 is a reply to message #133802] |
Fri, 01 December 2006 15:46  |
I installed eclipse 3.2 on August 8th this year and visual editor on August
9th. On Oct. 3 I installed version 3.2.1. At various times I have used
Help->Software Updates->Manage Configuration->Scan for Updates to update my
installation. ve was updated most recently on Nov 29th.
I don't know whether ve has ever been working. I only started trying to use
it this week.
news:ekq2g1$aeu$2@utils.eclipse.org...
> into?
>> only place I see any evidence of the visual editor is in help. So at
>> least the help for ve got installed properly. I tried creating a new
>> java project just in case there was something weird about the
>> configuration of my existing projects, but that didn't help, either.
>> There was still no option to create a new visual class.
>>>> tried updating all my features but it hasn't helped. The error log
>>>> does not show any errors from Eclipse startup. Although I'm currently
>>>> interested in getting VE to work, in general, how does one debug
>>> Thanks,
>>> Rich Kulp
> Rich Kulp
Re: Another case of VE not showing up after installation [message #614834 is a reply to message #133826] |
Fri, 01 December 2006 17:42  |
Some progress. I installed callisto and visual editor is now showing up on
the context menu for existing java files and I can create a new visual
class. But if I try to open a file in ve I get 2 errors and no editor
appears, although a tab for the file that says "Visual Editor" is created.
Clicking on the tab generates 2 more similar errors.
From the error log:
eclipse.buildId=M20060629-1905
java.version=1.5.0_09
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Documents and
Settings\kcrews\workspace\.metadata\.bak_0.log
Created Time: 2006-12-01 16:47:43.631
Error
Fri Dec 01 17:39:00 EST 2006
Unhandled event loop exception
Error
Fri Dec 01 17:38:31 EST 2006
org/eclipse/gef/commands/Command
java.lang.NoClassDefFoundError: org/eclipse/gef/commands/Command
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
at
at
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:383)
at
at
at
at
at
at
at
at
at
at
at
at
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.eclipse.ve.internal.cde.core.EditDomain.<init>(EditDomain.java:188)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.init(JavaVisualEditorPart.java:268)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:840)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:583)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2595)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2528)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2520)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2505)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2500)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:288)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:280)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:184)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Another case of VE not showing up after installation [message #614836 is a reply to message #133790] |
Sat, 02 December 2006 04:35  |
Originally posted by: hoeppie.gmx.de
Hi there,
did you try to start eclipse with the "-clean" option?
It es someimes needed to reinit plugins.
"Cleans cached data used by the OSGi framework and Eclipse runtime. Try
to run Eclipse once with this option if you observe startup errors after
install, update, or using a shared configuration. "
Cheers Dirk
Re: Another case of VE not showing up after installation [message #614840 is a reply to message #133852] |
Mon, 04 December 2006 15:15  |
to work.
ve is now working.
Re: Another case of VE not showing up after installation [message #614841 is a reply to message #133912] |
> to work.
> ve is now working.
Rich Kulp
FUDForum. Page generated in 0.06834 seconds
