Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » ECORE 2 XML Schema and back
ECORE 2 XML Schema and back [message #133581] Wed, 25 February 2009 03:39 Go to next message
Hi all,
I generated XML Schema from ECORE using "Generator -> Export model..."
option. And the generated Schema contains attributes in ecore namespace "
http://www.eclipse.org/emf/2002/Ecore". May I assume that this kind of
transformation is reversible, so that next time I will generate ECORE back
from this schema I will get exactly the same ECORE model? Is there any
limitations on that?
Thanks!
Renat
Re: ECORE 2 XML Schema and back [message #133635 is a reply to message #133581] Wed, 25 February 2009 10:15 Go to previous messageGo to next message
Renat,
Yes, the idea is that Ecore -> XSD -> Ecore should be a round trip.
It's possible that I've overlooked something, but if so, you can report
it and I'll fix it. This is really an EMF question, not an EMFT question...
Renat Zubairov wrote:
> Hi all,
> Thanks!
> Renat
Re: ECORE 2 XML Schema and back [message #133648 is a reply to message #133635] Wed, 25 February 2009 16:02 Go to previous messageGo to next message
Thans Ed for reply. I tried it on Extended library model. I transformed the
ecore to XSD and then generated ecore again from the XSD I've got before.
Then I turn it to XSD again and... All element definitions that were
mentoned in XSD are gone. Also transitive, derived and volatile attributes
have not survived the round trip in the ECORE. Also one attribute
(people:EFeatureMapEntry) didn't survived either.
But most interesting part is that all types were changing the namespace, see
the example here:
http://screencast.com/t/zoa3wMLujP2
They used to be defined in http://www.eclipse.org/... Ecore.ecore... but
after roundtrip they became /plugin/org..../Ecore.ecore...
Renat
On 25.02.09 16:15, in article go3nb0$qlu$2@build.eclipse.org, "Ed Merks"
<Ed.Merks@gmail.com> wrote:
> Renat,
>> Hi all,
>> Thanks!
>> Renat
Re: ECORE 2 XML Schema and back [message #133660 is a reply to message #133648] Wed, 25 February 2009 16:36 Go to previous message
--------------030605000809090204080409
Renat,
Comments below.
I didn't say XSD -> Ecore -> XSD is a round trip.
Yes, I think you're right about the transient thing. They're really not
supposed to be in the XSD given they are transient and hence not
serialized...
> the example here:
The Ecore model is kind of special so these two versions of it are
effectively equivalent when it comes to their use as data types.
> Renat
>> Renat,
>>> Hi all,
>>> Thanks!
>>> Renat
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Renat,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:C5CB705B.1AAD%25renat.zubairov@sopera.de"
type="cite">
<pre wrap="">Thans Ed for reply. I tried it on Extended library model. I transformed the
mentoned in XSD are gone. </pre>
</blockquote>
I didn't say XSD -&gt; Ecore -&gt; XSD is a round trip.<br>
type="cite">
<pre wrap="">Also transitive, derived and volatile attributes
</pre>
</blockquote>
Yes, I think you're right about the transient thing.&nbsp; They're really
not supposed to be in the XSD given they are transient and hence not
serialized...<br>
type="cite">
<pre wrap="">But most interesting part is that all types were changing the namespace, see
the example here:
<a class="moz-txt-link-freetext" href="http://screencast.com/t/zoa3wMLujP2">http://screencast.com/t/zoa3wMLujP2</a>
They used to be defined in <a class="moz-txt-link-freetext" href="http://www.eclipse.org/">http://www.eclipse.org/</a>... Ecore.ecore... but
</pre>
</blockquote>
effectively equivalent when it comes to their use as data types.<br>
type="cite">
<pre wrap="">
Renat
On 25.02.09 16:15, in article <a class="moz-txt-link-abbreviated" href="mailto:go3nb0$qlu$2@build.eclipse.org">go3nb0$qlu$2@build.eclipse.org</a>, "Ed Merks"
<a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com">&lt;Ed.Merks@gmail.com&gt;</a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Renat,
Yes, the idea is that Ecore -&gt; XSD -&gt; Ecore should be a round trip.
</pre>
<pre wrap="">Hi all,
I generated XML Schema from ECORE using "Generator -&gt; Export model..."
option. And the generated Schema contains attributes in ecore namespace <a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore">"
http://www.eclipse.org/emf/2002/Ecore"</a>. May I assume that this kind of
Thanks!
Renat
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------030605000809090204080409--
Re: ECORE 2 XML Schema and back [message #620689 is a reply to message #133581] Wed, 25 February 2009 10:15 Go to previous message
Renat,
> Hi all,
> Thanks!
> Renat
Re: ECORE 2 XML Schema and back [message #620690 is a reply to message #133635] Wed, 25 February 2009 16:02 Go to previous message
the example here:
They used to be defined in http://www.eclipse.org/.. Ecore.ecore... but
Renat
> Renat,
>> Hi all,
>> Thanks!
>> Renat
Re: ECORE 2 XML Schema and back [message #620691 is a reply to message #133648] Wed, 25 February 2009 16:36 Go to previous message
Renat,
Comments below.
serialized...
> the example here:
> Renat
>> Renat,
>>> Hi all,
>>> Thanks!
>>> Renat
<html>
<head>
</head>
Renat,<br>
<br>
Comments below.<br>
<br>
type="cite">
</blockquote>
type="cite">
</pre>
</blockquote>
serialized...<br>
type="cite">
the example here:
</pre>
</blockquote>
type="cite">
<pre wrap="">
Renat
</pre>
<pre wrap="">Renat,
</pre>
Thanks!
Renat
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Previous Topic:teneo downloads
Next Topic:Merging multiple EMF editors
Current Time: Tue Jul 22 01:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.09589 seconds
