Home » Modeling » Papyrus » TOPCASED Connect to a SVN Server using https(Connect to a SVN Server using https)
TOPCASED Connect to a SVN Server using https [message #1333792] Mon, 05 May 2014 04:23 Go to next message
I'm having problem to connect TOPCASED to my SVN server. When I use the function
SVN repositories or SVN repository browser, I fill in the URL to my freshly created SVN server then my user + password. But it doesn't pass the "validate repository location" and requires continuously my user+pwd...
On the other side, I can access to my SVN server by using a browser.
Can you help me solve this problem ?
Thanks in advance for any support !
Philip LOUCOPOULOS
  • Attachment: Capturer.JPG
    (Size: 133.24KB, Downloaded 241 times)
[Updated on: Tue, 06 May 2014 09:41] by Moderator
Re: TOPCASED 5.3.0 and SVN [message #1334276 is a reply to message #1333792] Mon, 05 May 2014 09:43 Go to previous messageGo to next message
I had similar problem using SVN 1.8 client tooling with an SVN 1.5 server.
My solution was to keep a TortoiseSVN 1.7 for use with this prehistoric
server since Eclipse SVN 1.7 tooling had greyed out for Luna.
I'm told 1.7 is now available again from
http://community.polarion.com/projects/subversive/download/eclipse/4.0/update-site/
Ed Willink
On 05/05/2014 14:08, Philip LOUCOPOULOS wrote:
> Hello,
> Regards,
> Philip LOUCOPOULOS
TOPCASED Connect to a SVN Server using https [message #1334354 is a reply to message #1334276] Mon, 05 May 2014 10:33 Go to previous message
Hi Ed,
Thank you for your answer !
Actually, I am running with the following version TortoiseSVN: 1.7.1. So this is not the pb.
What is happening is the following:
The connection to my https SVN server does not happen, the message is:
java.lang.SecurityException: Impossible de trouver une configuration de connexion
What is this configuration connection ?
Does TOPCASED 5.3.0 allow to connect via htpps to a Visual SVN Server ?
Thank you
Philip
Previous Topic:Moving with mouse inside diagram view
Next Topic:How to show stereotype properties in a class diagram?
Current Time: Sun Jul 27 18:50:19 EDT 2025
Powered by FUDForum. Page generated in 0.04606 seconds
