| Automatically generated UI code [message #133393] |
Thu, 23 November 2006 12:12  |
Originally posted by: alex_blewitt.yahoo.com
I posted a thread on EZ's front page about automatically generated UI code:
http://www.eclipsezone.com/eclipse/forums/t84836.html
I hope I characterised what VE can do. However, a tangential discussion came up about VAJ's old event- and property- hooking mechanisms. Am I right in saying that VE is just concerned about building UI code, as opposed to designing non-UI code graphically?
Alex.
| Re: Automatically generated UI code [message #133544 is a reply to message #133393] |
Mon, 27 November 2006 11:14  |
You can create event/property callbacks through the VE. It will then
provide a template callback class which you can update to provide the
actual function. The VE does not graphically link two components through
events/properties.
This is done through the popup menu on a visual component. You will see
the events menu item, and it will list the preferred events/properties,
or you can bring up a dialog to select another event or property.
> Alex.
Rich Kulp
| Re: Automatically generated UI code [message #614812 is a reply to message #133393] |
events/properties.
> Alex.
Rich Kulp
FUDForum. Page generated in 0.27848 seconds
