Re: What is the minimal work to do from installing TPTP to profiling a java application ? [message #133449 is a reply to message #133419] |
Mon, 28 July 2008 13:22  |
You can start an profiling session with 'Run' > 'Profile Configuration' to
launch a configuration. Within the configuration dialog, under the 'monitor'
tab, make sure you select the profile and configure the profiling filter to
include your java application package/class/method (Edit Option button).
CPU usage statistics is available under option 'Execution Time Analysis' >
'collect method CPU time information'.
Eugene
"Name" <none@domain.invalid> wrote in message
news:g6kd7h$es6$1@build.eclipse.org...
> i just installed TPTP from the update manager (this is the version 4.3.100
> wich was found).
> Now i'd like to profile my java app, but my profiling monitor seems to log
> nothing at all.
> What should i do to get some CPU usage statistics ?
> Thanks
FUDForum. Page generated in 0.04067 seconds
