Home » Archived » Test and Performance Tools Platform (TPTP) » monitor page not showing
monitor page not showing [message #133085] |
Wed, 23 July 2008 05:25  |
I have a strange problem. I can not profile with eclipse 3.4 + TPTP
4.5.0 (on Vista).
When I bring up the Launch Configuration Dialog it tells me, that I have
to select a monitor.
But when I switch to the monitor page.. It does not appear.
Eclipse as whole freezes, and never comes back.
When I try to test the agent controller and go Window / Preferences /
Agent Controller / Hosts and press the "Test Connection" button. The
same happens, eclipse freezes and never comes back.
From here on the only way left is to kill eclipse and start it again
(but with no intention of profiling).
There is no information in the log, to make things worse.
Does anyone have an idea of what is going on ?
Re: monitor page not showing [message #133256 is a reply to message #133085] |
Fri, 25 July 2008 10:18   |
Hi Kristof,
There may be something wrong with the Agent Controller(AC) setup. Please try
the following to quickly test the AC setup.
Before you do anything, shut down Eclipse, and make sure there is dangling
process of java.exe nor ACServer.exe
If you are using an TPTP all-in-one driver, Under
Eclipse\dropins\eclipse\plugins\org.eclipse.tptp.platform.ac .win_ia32_4.4.1.v200806171132\agent_controller\bin,
run the following command:
SetConfig.bat
keep all default value (simply press entry to pass an input prompt)
now. try with following command:
ACServer.exe
and this should manually startup an AC with no error message prompt.
If everything run okay so far, now try launch Eclipse and open and monitor
tab again.
In Vista, make sure you have read/write access to the folder and subfolder
of
eclipse\dropins\eclipse\plugins\org.eclipse.tptp.platform.ac .win_ia32_4.4.1.v200806171132\agent_controller
Hope this helps
Eugene
"Kristof Szabados" <szabadosk@yahoo.com> wrote in message
news:g66te1$7j8$1@build.eclipse.org...
> I have a strange problem. I can not profile with eclipse 3.4 + TPTP 4.5.0
> (on Vista).
> Agent Controller / Hosts and press the "Test Connection" button. The same
> From here on the only way left is to kill eclipse and start it again (but
> Thanks
Re: monitor page not showing [message #133342 is a reply to message #133256] |
Fri, 25 July 2008 12:03   |
Hi Eugene.
Sorry, but it did not work.
The ACServer did start up, but even though it was running it seems I was
not able to connect to it.
And actually the worst part is not that I'm not able to connect to it,
but that seemingly there is no timeout, giving me no other option than
to kill eclipse.
Which in return makes the next eclipse start take a few minutes /* I
guess it believes that the workbench was damaged, and tries to
validate/repair it */
Best Regards
Eugene Chan wrote:
> Hi Kristof,
> SetConfig.bat
> ACServer.exe
> tab again.
> of
> Hope this helps
> Eugene
>> Hi,
>> (on Vista).
>> Thanks
Re: monitor page not showing [message #133367 is a reply to message #133342] |
Fri, 25 July 2008 12:47   |
Could you please check and see if
Eclipse\dropins\eclipse\plugins\org.eclipse.tptp.platform.ac .win_ia32_4.4.1.v200806171132\agent_controller\config\servic econfig.xmlexists and not empty. It is usually about 88-90 lines in the the file, app.6KB in size.I am not sure if anything is corrupted during unzip of the driver, but couldyou try download a new driver and try with a fresh workspace.Which TPTP build are you using?Eugene"Kristof Szabados" <szabadosk@yahoo.com> wrote in messagenews:g6cth9$3c0$1@build.eclipse.org...> Hi Eugene.>> Sorry, but it did not work.>> The ACServer did start up, but even though it was running it seems I wasnot able to connect to it.>> And actually the worst part is not that I'm not able to connect to it, butthat seemingly there is no timeout, giving me no other option than to killeclipse.> Which in return makes the next eclipse start take a few minutes /* I guessit believes that the workbench was damaged, and tries to validate/repair it*/>> Best Regards>>> Eugene Chan wrote:>> Hi Kristof,>>>> There may be something wrong with the Agent Controller(AC) setup. Pleasetry the following to quickly test the AC setup.>> Before you do anything, shut down Eclipse, and make sure there isdangling process of java.exe nor ACServer.exe>> If you are using an TPTP all-in-one driver, UnderEclipse\dropins\eclipse\plugins\org.eclipse.tptp.platfo rm.ac.win_ia32_4.4.1.v200806171132\agent_controller\bin, run the following command:>> SetConfig.bat>> keep all default value (simply press entry to pass an input prompt)>> now. try with following command:>> ACServer.exe>> and this should manually startup an AC with no error message prompt.>> If everything run okay so far, now try launch Eclipse and open andmonitor tab again.>>>> In Vista, make sure you have read/write access to the folder andsubfolder ofeclipse\dropins\eclipse\plugins\org.eclipse.tptp.platform. ac.win_ia32_4.4.1.v200806171132\agent_controller >>>>>> Hope this helps>> Eugene>>>> "Kristof Szabados" <szabadosk@yahoo.com> wrote in messagenews:g66te1$7j8$1@build.eclipse.org...>>> Hi,>>>>>> I have a strange problem. I can not profile with eclipse 3.4 + TPTP4.5.0 (on Vista).>>>>>> When I bring up the Launch Configuration Dialog it tells me, that I haveto select a monitor.>>> But when I switch to the monitor page.. It does not appear.>>> Eclipse as whole freezes, and never comes back.>>>>>> When I try to test the agent controller and go Window / Preferences /Agent Controller / Hosts and press the "Test Connection" button. The samehappens, eclipse freezes and never comes back.>>>>>> From here on the only way left is to kill eclipse and start it again(but with no intention of profiling).>>>>>> There is no information in the log, to make things worse.>>>>>> Does anyone have an idea of what is going on ?>>>>>> Thanks>>
Re: monitor page not showing [message #133380 is a reply to message #133342] |
Fri, 25 July 2008 12:48   |
I am resending this reply as I see problem in my last note.
Eclipse\dropins\eclipse\plugins\org.eclipse.tptp.platform.ac .win_ia32_4.4.1.v200806171132\agent_controller\config\servic econfig.xmlexists and not empty.It is usually about 88-90 lines in the the file, app.6KB in size.I am not sure if anything is corrupted during unzip of the driver, butcouldyou try download a new driver and try with a fresh workspace.Which TPTP build are you using?Eugene"Kristof Szabados" <szabadosk@yahoo.com> wrote in messagenews:g6cth9$3c0$1@build.eclipse.org...> Hi Eugene.>> Sorry, but it did not work.>> The ACServer did start up, but even though it was running it seems I wasnot able to connect to it.>> And actually the worst part is not that I'm not able to connect to it, butthat seemingly there is no timeout, giving me no other option than to killeclipse.> Which in return makes the next eclipse start take a few minutes /* I guessit believes that the workbench was damaged, and tries to validate/repair it*/>> Best Regards>>> Eugene Chan wrote:>> Hi Kristof,>>>> There may be something wrong with the Agent Controller(AC) setup. Pleasetry the following to quickly test the AC setup.>> Before you do anything, shut down Eclipse, and make sure there isdangling process of java.exe nor ACServer.exe>> If you are using an TPTP all-in-one driver, UnderEclipse\dropins\eclipse\plugins\org.eclipse.tptp.platfo rm.ac.win_ia32_4.4.1.v200806171132\agent_controller\bin, run the following command:>> SetConfig.bat>> keep all default value (simply press entry to pass an input prompt)>> now. try with following command:>> ACServer.exe>> and this should manually startup an AC with no error message prompt.>> If everything run okay so far, now try launch Eclipse and open andmonitor tab again.>>>> In Vista, make sure you have read/write access to the folder andsubfolder ofeclipse\dropins\eclipse\plugins\org.eclipse.tptp.platform. ac.win_ia32_4.4.1.v200806171132\agent_controller >>>>>> Hope this helps>> Eugene>>>> "Kristof Szabados" <szabadosk@yahoo.com> wrote in messagenews:g66te1$7j8$1@build.eclipse.org...>>> Hi,>>>>>> I have a strange problem. I can not profile with eclipse 3.4 + TPTP4.5.0 (on Vista).>>>>>> When I bring up the Launch Configuration Dialog it tells me, that I haveto select a monitor.>>> But when I switch to the monitor page.. It does not appear.>>> Eclipse as whole freezes, and never comes back.>>>>>> When I try to test the agent controller and go Window / Preferences /Agent Controller / Hosts and press the "Test Connection" button. The samehappens, eclipse freezes and never comes back.>>>>>> From here on the only way left is to kill eclipse and start it again(but with no intention of profiling).>>>>>> There is no information in the log, to make things worse.>>>>>> Does anyone have an idea of what is going on ?>>>>>> Thanks>>
Re: monitor page not showing [message #133668 is a reply to message #133380] |
Fri, 01 August 2008 13:44   |
The file does exist, and is 88 lines long.
I have the following versions:
/* as displayed in the About Eclipse SDK dialog*/
Eclipse SDK
Version: 3.4.0
Build id: I20080617-2000
TPTP Core
Version: 4.5.0.v200806121215-8Z8DEm8ELRXmpromDKxVI_
Build id: TPTP-4.5.0-200806200100
TPTP Analysis Feature
Version: 4.4.100.v200806050100-7F7_EAU_kE77c7U7Q7A77
TPTP Analysis Engine
Version: 4.3.200.v200806050100-784Ag8s733I3C5_4_59
I have downloaded this allinone package for windows from eclipse.org.
/* with the file name
tptp.runtime.allInOne.win32.win32.x86-TPTP-4.5.0.zip */
In the last 1-2 weeks I have installed this version a few times,
sometimes starting with a new workspace to get a bit further, with not
much of a success.
Best Regards
Kristof
Re: monitor page not showing [message #133679 is a reply to message #133668] |
Sat, 02 August 2008 05:16  |
As mentioned in an other thread the removing of the SOCKS proxy settings
is able to solve this problem.
BR
Kristof
Kristof Szabados wrote:
> Eclipse SDK
> Version: 3.4.0
> TPTP Core
> much of a success.
> Best Regards
> Kristof
>> Hi Kri
> all-in-one driver,
Current Time: Thu Jul 24 21:41:20 EDT 2025
Powered by FUDForum. Page generated in 0.27610 seconds
