Home » Eclipse Projects » Remote Application Platform (RAP) » TableViewer and vertical scrolling
TableViewer and vertical scrolling [message #133308] |
Tue, 19 May 2009 03:53  |
I have a table viewer and a vertical scrollbar. If I have to scroll
vertical and come out of my window size with the vertical scrolling, the
table header is cutting of and dispose. That means, the table header
doesn't show.
It is a bug in RAP or there is a solution for this problem?
kristin
Re: TableViewer and vertical scrolling [message #133332 is a reply to message #133324] |
Tue, 19 May 2009 04:20   |
The table viewer isn't in a ScrolledComposite.
Here is a code snippet of my table viewer.
public static final String[] PROCESS_STATUS_ITEMS = {"jbpmInstanceId",
"tokenId","processInstanceId","parentTokenId",
"superProcessTokenId","subProcessTokenId","status","processName ",
"patchVersion","phase","phaseTimestamp","state","stateTimestamp ",
"additionalData","replacementProcessInstanceId","techId", "customerId",
"ccdId","contractId","timerInfo","lastEventTimestamp", "lastEventType",
"failedJobInfo"
Re: TableViewer and vertical scrolling [message #133345 is a reply to message #133332] |
Tue, 19 May 2009 04:26   |
Sorry, the post was not ready.
So, here is the complete code snippet.
{"jbpmInstanceId","tokenId","processInstanceId","parentTokenId ",
"failedJobInfo"};
private class ViewLabelProvider
extends LabelProvider
implements ITableLabelProvider
public Image getColumnImage( Object element, int columnIndex ) {
return null;
public String getColumnText( Object element, int columnIndex ) {
String[] row = ( String[] )element;
String result = row[ columnIndex ];
return result;
private class ViewContentProvider implements IStructuredContentProvider {
public Object[] getElements( Object inputElement ) {
int s = 10;
Object[] rows = new Object[s];
for (int i = 0; i < s; i++) {
String[] row = new String[ PROCESS_STATUS_ITEMS.length ];
for( int j = 0; j < PROCESS_STATUS_ITEMS.length; j++ ) {
row[j] = "test" + i;
rows[i] = row ;
return rows;
public void dispose() {
public void inputChanged( Viewer viewer, Object oldInput,
Object newInput ) {
private String[] initColumnProperties( final Table table ) {
String[] result = new String[ PROCESS_STATUS_ITEMS.length ];
for( int i = 0; i < PROCESS_STATUS_ITEMS.length; i++ ) {
tableColumn = new TableColumn( table, SWT.CENTER);
result[ i ] = PROCESS_STATUS_ITEMS[i] ;
tableColumn.setText( result[ i ] );
tableColumn.setWidth(170);
return result;
public void createPartControl(Composite parent) {
tableViewer = new TableViewer( parent, SWT.MULTI | SWT.V_SCROLL
| SWT.H_SCROLL);
tableViewer.setContentProvider( new ViewContentProvider() );
tableViewer.setLabelProvider( new ViewLabelProvider() );
final Table table = tableViewer.getTable();
tableViewer.setColumnProperties( initColumnProperties( table ) );
tableViewer.setInput(this);
tableViewer.getTable().setHeaderVisible( true );
tableViewer.getTable().setLinesVisible(true);
kristin
Re: TableViewer and vertical scrolling [message #133358 is a reply to message #133345] |
Tue, 19 May 2009 05:05   |
Hi Kristin,
your snippet is running fine. What I do not understand where is the
vertical scrollbar? How to make the header to cut off? Any steps to
reproduce it?
Best,
Ivan
> "failedJobInfo"};
> private class ViewLabelProvider extends LabelProvider
> return null;
> return result;
> int s = 10;
> rows[i] = row ;
> return rows;
> Object newInput ) {
> return result;
> SWT.V_SCROLL | SWT.H_SCROLL);
> kristin
Current Time: Sat Jul 26 15:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.26712 seconds
