agent library failed to init: JPIBootLoader [message #133137] |
Wed, 23 July 2008 17:43  |
Originally posted by: jbrobert.verizon.net
I've searched the groups, google, etc, and nothing I've found has helped
me.
I'm running Eclipse Version: 3.3.2 Build id: M20080221-1800 under Windows
XP. I've installed the most recent, as of last week, TPTP plugins from
the Europa discovery site.
I create a server, my local tomcat installation on the same machine I'm
running Eclipse. I use "take control of local installation". Just to be
safe, I (re)define
JAVA_PROFILER_HOME
C:\eclipse\plugins\org.eclipse.tptp.platform.jvmti.runtime_4 .4.100.v200804021410\agent_files\win_ia32
TPTP_AC_HOME
C:\eclipse\plugins\org.eclipse.tptp.platform.ac.win_ia32_4.4 .1.v200709261752\agent_controller
And have it appended to native environment.
Server starts up fine for both run/debug. In the profile dialog, I create
a new "Apache Tomcat" based upon the server above. When I launch the
profiling and select the pre JRE 1.5 tools, everything works fine, more or
less. However, if I select JRE 1.5 or greater tools, I get:
Error occurred during initialization of VM
I've tried adding -agentlib... to vm args in launch parameters for the
server, etc, nothing has worked. FWIW, I'm completely new using the TPTP
tools, and, again, I'm trying to do this with the IAC, I guess, since both
my eclipse and the tomcat installation are on the same machine.
Any help about how to troubleshoot this would be greatly appreciated -
also, doing the tutorial included with the TPTP tools, I was able to use
the JRE 1.5 or better profiling tools.
Jay Roberts
FUDForum. Page generated in 0.03941 seconds
