Home » Archived » Test and Performance Tools Platform (TPTP) » my test*.execution could not be edited
my test*.execution could not be edited [message #132899] Thu, 17 July 2008 17:30 Go to next message
Originally posted by: real.self.gmail.com
I created a helloworld java program, and created a tptp junit test file.
Then I run my created test.testsuite which generated a test.execution
file. I simply could not open this file.
Any tips are welcomed.
Best.
jiangfan
PS. the detailed failure stack:
at
org.eclipse.hyades.test.ui.forms.base.VerdictSummaryChart.<init >(VerdictSummaryChart.java:110)
at
org.eclipse.hyades.test.ui.forms.editor.page.LogOverviewPage .createOverviewPart(LogOverviewPage.java:142)
at
org.eclipse.hyades.test.ui.forms.editor.page.LogOverviewPage .createFormContent(LogOverviewPage.java:98)
at org.eclipse.ui.forms.editor.FormPage$1.run(FormPage.java:151 )
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.forms.editor.FormPage.createPartControl(FormP age.java:149)
at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor .java:488)
at
org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiP ageEditorPart.java:973)
at
org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEdi tor.java:623)
at
org.eclipse.hyades.test.ui.forms.editor.TestLogViewer.addPag es(TestLogViewer.java:55)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:146)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at
org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
at
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:363)
at
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:603)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Re: my test*.execution could not be edited [message #132913 is a reply to message #132899] Fri, 18 July 2008 06:11 Go to previous messageGo to next message
This has since been fixed under
https://bugs.eclipse.org/bugs/show_bug.cgi?id=239660. Please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=239660#c3 for the cause of the
problem. To work around the problem, please install BIRT/DTP/GEF from
http://www.eclipse.org/tptp/home/downloads/?ver=4.5.0#tptp-p lugins and
restart Eclipse with the -clean flag.
Paul
"jiangfan shi" <real.self@gmail.com> wrote in message
news:302f5e315aa48eeac4f4f166de92e41d$1@www.eclipse.org...
> Any tips are welcomed. Best.
> jiangfan
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: my test*.execution could not be edited [message #132926 is a reply to message #132913] Fri, 18 July 2008 09:38 Go to previous message
Thanks, Paul. It works now.
Best,
Jiangfan
Previous Topic:I could not open static analysis windows
Next Topic:relations between tested methods and test cases
Current Time: Wed Jul 23 18:55:29 EDT 2025
Powered by FUDForum. Page generated in 0.04086 seconds
