Ganymede TPTP 4.5 - Call Tree shows only thread level [message #132661] |
Mon, 14 July 2008 09:53  |
Originally posted by: gshumakher.gmail.com
I am profiling WTP application that running in Tomcat with jvm 1.6.
For some reason the Call Tree tab of Execution Time Analysis shows me
only 1th thread level, bun not the subsequent classes that were
executed. When I press + in the tree the + sign just disappears.
What could be the problem?
Gennady
Re: Ganymede TPTP 4.5 - Call Tree shows only thread level [message #132702 is a reply to message #132689] |
Mon, 14 July 2008 11:35   |
Originally posted by: gennady.backflipsoftware.com
Hi Eugene,
To be sure I specified the package filter as *.* (INCLUDE) and set 'No
filter' in the Execution Statistics tab of Execution Statistics view.
I do see packages, classes and methods with their performance statistics in
the Execution Statistics tab, but for some reason the Call Tree tab shows
only 1st level of threads.
Just to confuse even more, when I open Execution Flow view I do see the
Call Tree sub-view with Threads and subsequent calls, but statistics columns
(Instance Name, Start Time, etc.) are empty (no data).
Gennady
"Eugene Chan" <ewchan@ca.ibm.com> wrote in message
news:g5fmcu$uid$1@build.eclipse.org...
> Hi Gennady,
> Did you set your profiling filter when starting your WTP application to
> include your package? Also check the VIEW filter to make sure it shows all
> your are expecting. The VIEW filter action button is on the toolbar of the
> view itself.
> Eugene
> "Gennady Shumakher" <gshumakher@gmail.com> wrote in message
> news:g5flpm$rrt$1@build.eclipse.org...
>> Hello,
>> only 1th thread level, bun not the subsequent classes that were executed.
>> Thanks,
>> Gennady
Re: Ganymede TPTP 4.5 - Call Tree shows only thread level [message #132811 is a reply to message #132798] |
Wed, 16 July 2008 09:00  |
Hi Gennady,
Profile on Server does not currently support Call Graph detail feature. To
workaround the problem, you will have to manually setup the server to start
in Run/Normal mode with VM argument that enables you to collect Call Graph
details.
In a server configuration, configure the VM argument field with the
following:
-agentlib:JPIBootLoader=JPIAgent:server=controlled;CGProf:ex ecdetails=true
and start the server in Run mode, then attach to the profiling process using
the Profile... > Attach to Agent configuration. You can set your profiling
filters in the Attach to Agent configuration.
Eugene
"Gennady Shumakher" <gennady@backflipsoftware.com> wrote in message
news:g5kp6d$2fk$1@build.eclipse.org...
> Hi Asaf,
> I activate profiler via eclipse integrated option available from
> WTP -Server view.
> Regards,
> Gennady
> "Asaf Yaffe" <asaf.yaffe@intel.com> wrote in message
> news:g5khmm$stk$1@build.eclipse.org...
>> Gennady,
>> Can you provide more information on how do you profile your Tomcat
>> applications? Are you using the integrated "Profiler on server" option?
>> Or maybe another technique?
>> Thanks,
>> Asaf
>> Asaf Yaffe
>> Eclipse TPTP Committer, JVMTI Profiler
FUDForum. Page generated in 0.06058 seconds
