Cannot find Progress Indicator in 3.0 M3 [message #128642] |
Fri, 12 September 2003 19:56  |
Originally posted by: harami.idis.co.kr
I cannot find the Progress Indicator in 3.0 M3.
(Windows XP, JDK 1.4.2)
When I move the mouse cursor to the bottom left hand corner of a workbench
window
the tooltip "Double Click to open Progress View" is shown and I double
click, Eclipse shows Progress View.
(Progress Indicator is still invisible)
Is it disabled by default?
I added the line org.eclipse.ui.workbench/showProgressIndicator=true to the
file
plugin_customization.ini in org.eclipse.platform, but it remains unchanged.
When I click the left margin (in Java Perspective) the Progress View shows
the message
"ERROR: Breakpoint location validation : Breakpoint cannot be set at the
given position"
(I think it's a bug in Quick Diff.) and Progress Indicator blinks in the
bottom left hand corner.
very strange...
Re: Cannot find Progress Indicator in 3.0 M3 [message #134473 is a reply to message #132626] |
Tue, 23 September 2003 11:05  |
Originally posted by: John_Arthorne.oti.com_
In M3 the indicator was moved from the top right to the bottom left,
mostly to support certain platforms where the toolbar and top level menu
can be removed. There is working going on right now to improve the
appearance and usability of the progress indicator. It will likely move
again by M4 ;)
Haram Lee wrote:
> I didn't mean progress animation. I cannot see progress indicator at all.
> The progress indicator exists the right hand corner of toolbar in M2.
> In M3, it does not. It seems be hidden in the bottom of shortcut bar and
> when the some problem occurs in concurrent process, suddenly it appears and
> blinks on.
> (pls refer the attached image)
> "John Arthorne" <John_Arthorne@oti.com_> wrote in message
> news:3F686EB4.4090600@oti.com_...
>>The progress animation only appears when there is actually background
>>work going on.
> workbench
>>>window
> the
>>>file
> unchanged.
> shows
>>>the message
>>>given position"
>>>very strange...
FUDForum. Page generated in 0.03807 seconds
