Home » Eclipse Projects » Remote Application Platform (RAP) » StatusBar, MessageBox, ... breaking UI window?
StatusBar, MessageBox, ... breaking UI window? [message #132580] Wed, 13 May 2009 05:03 Go to next message
Folks;
not sure how to completely get to the bottom of this problem: In a given
situation I want to have the user notified that something actually happened
after "clicking an icon" in my RAP application coolbar. Well... So far I
tried to go for two different approaches:
(a) Use a MessageBox started from within the AbstractHandler implementations
execute() method that gets invoked whenever the button is being presed.
(b) Use some global helper class to access (and write to) the application
status line, more or less following the approach outlined in [1].
While both approaches basically work, in both situations I see that either
after the status line has been updated or after the message box has been
displayed, the UI perspective gets messed up completely: It seems the "RAP
application window" is extended way beyond the boundaries of the screen, the
status line is not visible anymore, neither are my views at the bottom of
the screen (well, not completely, parts of the Forms components which are in
one of the views still are there yet somehow painted "over" another view).
Only way to restore this, by then, is to restart the RAP session which is
_rather_ inconvenient... So to ask:
- Is this a known issue / limitation, ...?
- Is there a workaround? At least the approach in [1] of how to access the
status bar from a non-view component seems somewhat clumsy, and I want to
make sure it's not the code itself causing a misbehaviour.
- Any other information required to track this down?
TIA and all the best,
Kristian
[1] http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg05917.html
Re: StatusBar, MessageBox, ... breaking UI window? [message #132607 is a reply to message #132580] Wed, 13 May 2009 05:26 Go to previous messageGo to next message
Adding to this, maybe of relevance: There is an exception being thrown in
one of the views containing a CTabFolder, but as far as I can tell, this
seems a consequence of trying to resize the widget rather than the reason
for resizing?
K.
SCHWERWIEGEND: Could not execute PhaseListener after phase 'PROCESS_ACTION'.
java.lang.ArrayIndexOutOfBoundsException: 0
at org.eclipse.swt.custom.CTabFolder.updateItems(CTabFolder.jav a:1294)
at org.eclipse.swt.custom.CTabFolder.updateItems(CTabFolder.jav a:1286)
at org.eclipse.swt.custom.CTabFolder.onResize(CTabFolder.java:1 822)
at org.eclipse.swt.custom.CTabFolder$1.controlResized(CTabFolde r.java:191)
at org.eclipse.swt.events.ControlEvent.dispatchToObserver(Contr olEvent.java:68)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.jav a:44)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.ja va:125)
at org.eclipse.swt.widgets.Control.notifyResize(Control.java:17 88)
at org.eclipse.swt.widgets.Composite.notifyResize(Composite.jav a:732)
Re: StatusBar, MessageBox, ... breaking UI window? [message #132644 is a reply to message #132607] Wed, 13 May 2009 07:56 Go to previous messageGo to next message
Hi Kristian,
are you experiencing this bug:
[Viewers] ArrayIndexOutOfBoundsException exception in
ConcurrentTableUpdator (used in DeferredContentProvider)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=165637
If so, you could add your findings to this bug.
Ralf
Re: StatusBar, MessageBox, ... breaking UI window? [message #132683 is a reply to message #132644] Wed, 13 May 2009 08:47 Go to previous message
Hmm, I think I mixed up something here. Your problem doesn't seem to be
related. Sorry for the noise.
However, feel free to file a new bug report for your problem.
Regards, Ralf
Previous Topic:Information on defaults Preferences
Next Topic:Problems with trees
Current Time: Sat Jul 19 02:31:58 EDT 2025
Powered by FUDForum. Page generated in 0.26022 seconds
