Home » Eclipse Projects » Equinox » How to garbage collect obsolete plugin versions?
How to garbage collect obsolete plugin versions? [message #132454] Mon, 08 June 2009 09:52 Go to next message
Originally posted by: eclipse-newsgroups.scharf.gr
Garbage Collections seems to be one of the concepts of p2:
http://wiki.eclipse.org/Equinox/p2/Concepts
I have lots of different versions of plugins in my installation,
how do I garbage collect them?
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: How to garbage collect obsolete plugin versions? [message #132466 is a reply to message #132454] Mon, 08 June 2009 11:57 Go to previous messageGo to next message
Michael Scharf wrote:
You can use the GC Application in p2.
'org.eclipse.equinox.internal.p2.garbagecollector.Applicatio n'
The argument is the profile you want to run the GC on.
I don't know if there is a better way to do this, maybe the p2 team can
shed light on this topic ;)
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: How to garbage collect obsolete plugin versions? [message #132492 is a reply to message #132454] Mon, 08 June 2009 13:05 Go to previous messageGo to next message
Garbage collection happens automatically after you've uninstalled or updated
something. What the GC worker does is goes through and deletes any of the
artifacts referenced in the bundle pool that are no longer referenced by the
current install/profile.
The application Chris mentions would allow a manual run of the GC which
might be useful in some situations but generally the automated GC should be
adequate.
I recall you using dropins and to be clear dropins are never GC'ed as these
are managed by the user. Are you seeing tons of garbage in your bundle pool?
-Simon
"Michael Scharf" <eclipse-newsgroups@scharf.gr> wrote in message
news:h0j53b$lke$1@build.eclipse.org...
> Michael
> Michael Scharf
Re: How to garbage collect obsolete plugin versions? [message #132537 is a reply to message #132492] Mon, 08 June 2009 19:09 Go to previous messageGo to next message
It turns out that p2 does garbage collection (at some
point). So, now when I look into the installation
it seems quite clean. I guess some restart is
needed....
Michael
> adequate.
> -Simon
>> Hi,
>> Michael
>> Michael Scharf
Michael Scharf
Re: How to garbage collect obsolete plugin versions? [message #132550 is a reply to message #132537] Mon, 08 June 2009 21:16 Go to previous messageGo to next message
Hmm,
I am still puzzled when the automatic GC happens.
I have a -configuration where the plugins are
not garbage collected.... I wish there was a button
to run the p2 GC...
Michael
> needed....
> Michael
>> updated something. What the GC worker does is goes through and deletes
>> any of the artifacts referenced in the bundle pool that are no longer
>> referenced by the current install/profile.
>> which might be useful in some situations but generally the automated
>> GC should be adequate.
>> these are managed by the user. Are you seeing tons of garbage in your
>> bundle pool?
>> -Simon
>>> Hi,
>>> Michael
>>> Michael Scharf
Michael Scharf
Re: How to garbage collect obsolete plugin versions? [message #132562 is a reply to message #132550] Tue, 09 June 2009 01:14 Go to previous messageGo to next message
Admittedly at times I have to. Why not open a bug.
-Simon
news:h0kd4g$3dg$1@build.eclipse.org...
> Hmm,
> to run the p2 GC...
> Michael
>> needed....
>> Michael
>>> be adequate.
>>> bundle pool?
>>> -Simon
>>>> Hi,
>>>> Michael
>>>> Michael Scharf
> Michael Scharf
Re: How to garbage collect obsolete plugin versions? [message #132590 is a reply to message #132550] Tue, 09 June 2009 11:24 Go to previous message
Originally posted by: dj_houghton.nospam.ca.ibm.com
I created a new bundle with an icon with the following block of code. In
fact, I just used the example SampleAction to make it even easier.
IProfileRegistry profileRegistry = (IProfileRegistry)
ServiceHelper.getService(Activator.getContext(),
IProfileRegistry.class.getName());
if (profileRegistry == null)
throw new RuntimeException("Unable to acquire the profile registry
service.");
IProfile profile = profileRegistry.getProfile("SDKProfile");
new GarbageCollector().runGC(profile);
MessageDialog.openInformation(window.getShell(), "Profile Garbage
Collector", "Profile garbage collection finished.");
> Hmm,
> to run the p2 GC...
> Michael
>> needed....
>> Michael
>>> deletes any of the artifacts referenced in the bundle pool that are
>>> no longer referenced by the current install/profile.
>>> bundle pool?
>>> -Simon
>>>> Hi,
>>>> Michael
>>>> Michael Scharf
Previous Topic:eclipse equinox bundle compile problem
Next Topic:[p2IU fetch] Ability to fetch a group of bundles
Current Time: Mon Jul 21 08:51:51 EDT 2025
Powered by FUDForum. Page generated in 0.03704 seconds
