UI Windows do not show up anymore... [message #132382] |
Sat, 21 October 2006 19:42  |
Originally posted by: harel.ben-attia.comverse.com
Hi all,
My UI windows stopped showing....
When i open a visual class, the "Loading" window appears for a few seconds,
and then i can see "sShell" and "this" as icons, but no actual window is
appearing...
This happens for all my visual classes, and cleaning the project does not
help. Looking at the log file, no error is written.
Using:
Eclipse SDK 3.2
EMF SDK 2.2.0
Graphical Editing Framework SDK 3.2.0
J2EE Standard Tool Project 1.5.0
Java EMF Model SDK 1.2.0
Visual Editor 1.2.0
Web Standard Tools Project 1.5.0
No new installations or anything like that. The trigger for this is probably
a total Eclipse crash i had. The first exceptions in the log file after the
crash are below.
Thanks a lot in advance,
RL
!ENTRY org.eclipse.ve.java.core 4 0 2006-10-21 06:36:52.156
!MESSAGE Exception thrown.
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:671)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XML Handler.java:2511)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2439)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:74)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:1929)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1833)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1768)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1576)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:876)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:82)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:854)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:626)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:533)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(XMLNSDocumentScannerImpl.java:330)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra gmentScannerImpl.java:1693)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 368)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1089)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:895)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.demandLoad(ProjectResourceSetImpl.java:83)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doLoadFromCache(VEModelCacheUtility.java:103)
at
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:100)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reConnect(JavaSourceTranslator.java:1134)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:910)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:597)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1978)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.jem.proxy 2 0 2006-10-21 06:37:31.296
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
org.eclipse.jem.internal.proxy.common.remote.CommandErrorExc eption-- Error
code:8 Value data:"null"
at
org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1254)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:454)
at
org.eclipse.jem.internal.proxy.vm.remote.CallbackHandler.ini tiateCallbackStream(CallbackHandler.java:47)
at
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.requestStream(RemoteVMServerThread.java:420)
at
org.eclipse.jem.internal.beaninfo.vm.ModelingBeanInfo.send(M odelingBeanInfo.java:546)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:317)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:221)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms(REMMethodProxy.java:178)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:102)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:98)
at
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeC atchThrowableExceptions(REMMethodProxy.java:231)
at
org.eclipse.jem.internal.beaninfo.adapters.BeanInfoDecorator Utility.introspect(BeanInfoDecoratorUtility.java:220)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:767)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:428)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:415)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getEvents(BeaninfoClassAdapter.java:1272)
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEvents(J avaClassImpl.java:1304)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.allEvents(BeaninfoClassAdapter.java:2311)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getAllEvents(BeaninfoClassAdapter.java:1280)
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getAllEvent s(JavaClassImpl.java:1326)
at
org.eclipse.ve.internal.java.codegen.java.EventsParser.getAd dSignitures(EventsParser.java:66)
at
org.eclipse.ve.internal.java.codegen.java.EventsParser.analy ze(EventsParser.java:99)
at
org.eclipse.ve.internal.java.codegen.java.EventsParser.addEv ents(EventsParser.java:170)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.analyzeEvents(JavaBeanModelBuilder.java:372)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:463)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$SharedToLocalUpdater.handleParseable(JavaSourceTranslator .java:429)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$SharedToLocalUpdater.run(JavaSourceTranslator.java:502)
at
org.eclipse.ve.internal.java.codegen.java.SnippetParseJob.do Run(SnippetParseJob.java:92)
at
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
Re: UI Windows do not show up anymore... [message #132534 is a reply to message #132521] |
Thu, 26 October 2006 08:31  |
Thanks a lot anyway. I think i'll open a bug for this.
RL
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:ehoimo$thr$3@utils.eclipse.org...
> If it's getting the same errors, then I don't know. Sorry.
> Harel Ben Attia wrote:
>> Hi Rich,
>> i've tried this again but it doesn't work.... I get "this" and "sShell"
>> as icons only on the visual part of the class.
>> Thanks a lot
>> RL
>> news:ehji2e$vr8$2@utils.eclipse.org...
>>> Try clearing the cache.
>>> 1) Bring up a VE, then close it and all other VE's.
>>> 2) Do Project->Clean...->Clean All and wait for build to complete.
>>> 3) Now try a VE.
>>> Thanks,
>>> Rich Kulp
> Rich Kulp
Re: UI Windows do not show up anymore... [message #614723 is a reply to message #132382] |
Sat, 21 October 2006 23:20  |
Hi again,
I get this kind of exceptions in the log (the warning appears for almost
every constructor call, not only the one shown below):
!ENTRY org.eclipse.ve.java.core 4 0 2006-10-22 05:18:17.343
!STACK 0
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:357)
at
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature$5. getResource(BeaninfoNature.java:233)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResourceFromHandlers(ProjectResourceSetImpl.java:1 08)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.delegatedGetResource(ProjectResourceSetImpl.java:61)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:372)
at
at
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:92)
at
at
at
at
!ENTRY org.eclipse.ve.java.core 2 0 2006-10-22 02:32:18.078
!MESSAGE
+++ Warning +++: Sun Oct 22 02:32:18 IST 2006 Skipping expression:
txtMaximumIterationsPerClient = new Text(cmpSimulationParameters, SWT.BORDER
| SWT.RIGHT)
!ENTRY org.eclipse.ve.java.core 4 0 2006-10-22 02:32:18.078
!MESSAGE Invalid PropertyDecorator
Re: UI Windows do not show up anymore... [message #614729 is a reply to message #132396] |
Mon, 23 October 2006 19:09  |
3) Now try a VE.
Rich Kulp
Re: UI Windows do not show up anymore... [message #614733 is a reply to message #132510] |
Wed, 25 October 2006 16:50  |
> Hi Rich,
> i've tried this again but it doesn't work.... I get "this" and "sShell" as
> Thanks a lot
> RL
>> 3) Now try a VE.
>> Thanks,
>> Rich Kulp
Rich Kulp
Re: UI Windows do not show up anymore... [message #614734 is a reply to message #132521] |
RL
>> Hi Rich,
>> Thanks a lot
>> RL
>>> 3) Now try a VE.
>>> Thanks,
>>> Rich Kulp
> Rich Kulp
FUDForum. Page generated in 0.05054 seconds
