Home » Language IDEs » Java Development Tools (JDT) » Eclipse stops debugging with no errors
Eclipse stops debugging with no errors [message #132441] Thu, 08 January 2004 12:30 Go to next message
Originally posted by: ra0239.email.sps.mot.com
I have an servlet application I built using Eclipse and the Tomcat Plugin
that reads from a file system and writes to an Oracle database. I needed
to add the ability to extract from the database and generate some XML
strings.
Using the Java web service development package (jwsdp 1.3, JAXB section) I
created the required class files by running a schema document through the
jwsdp-JAXB tool. I uploaded the package into an Eclipse Project and
pointed to the jwsdp jar files and successfully generated an example xml.
The problem occurs when I try to extend my "Eclipse/Tomcat/Oracle Project"
to use the "Eclipse jwsdp xml generator Project" as a project reference or
as a jar file that I created using Eclipse. The revised
"Eclipse/Tomcat/Oracle Project" will compile fine referncing the new
classes but as soom as I try to use one of the class files in the "Eclipse
jwsdp xml generator Project" or as a jar file, the debug just stops, and I
don't get any errors or see any output in the Eclipse console. It just
STOPS!
My current environment:
Eclipse Version: 2.1.1 Build id: 200306271545
Tomcat Plugin 2.1.1
Windows 2K
Re: Eclipse stops debugging with no errors [message #132791 is a reply to message #132441] Fri, 09 January 2004 09:26 Go to previous messageGo to next message
Is there anything in you ".log" file? From your description is in unclear
how you launch your app.
Darin
"Stephen Chelstrom" <ra0239@email.sps.mot.com> wrote in message
news:btk43v$3cq$1@eclipse.org...
> strings.
> STOPS!
> Tomcat Plugin 2.1.1
> Windows 2K
Re: Eclipse stops debugging with no errors [message #133028 is a reply to message #132791] Fri, 09 January 2004 11:52 Go to previous messageGo to next message
Steve Chelstrom wrote:
I am using the Tomcat Plugin from sysdeo and I launch the application by
starting Tomcat from the Tomcat pulldown menu in Eclipse and then I go to
the web page for the servlet and select a menu item from the web page
which starts the servlet running. The servlet will start two timers. The
first timer will read a file and then write to the database and the second
timer will generate an XML output to the console using the jwsdp-JAXB
generated classes.
The timers work fine and I only see the problem when I add the calls to
the second timer which create the xml example via accessing the jar file I
created using the jwsdp-JAXB libraries.
The crazy part is that I can compile and run the xml example in a
standalone eclipse project. I can also compile and run the file reader and
oracle upload project in a standalone eclipse project but whenever I try
to combine them, as soon as it hits a file with reference to the
jwsdp-JAXB classes it stops. I have checked the log files on Tomcat and
not seen any problems. The servlet doesn't terminate it just stops.
Steve
> Darin
> > strings.
> > STOPS!
> > Tomcat Plugin 2.1.1
> > Windows 2K
Re: Eclipse stops debugging with no errors [message #133041 is a reply to message #133028] Fri, 09 January 2004 16:18 Go to previous messageGo to next message
Stephen Chelstrom wrote:
More Details: I created a JAXB package with the Java Web Server
Development Toolkit (jwsdp 1.3) that uses xercesImpl.jar (v2.3.0). This
package was created automatically when I ran the ant build and pass it a
schema document. I imported this package into Eclipse and wrote a small
main file that prints out an example xml file to the console. This worked
and I wanted to use the JAXB package with my Oracle Project but whensever
I read in a file which uses a class from the JAXB package it STOPS
Debugging with no errors.
Could the problem be related to the Xerces XML Parser Plugin used in
Eclipse and the xercesImpl.jar (v2.3.0) I am using to build the JAXB
package?
I am now trying to build the JAXB package in Eclipse and I get the
following error:
Buildfile: C:\Program
Files\JavaSoft\eclipse\workspace\semiJaxb\WEB-INF\src\semiG8 x\build.xml
compile:
[echo] Compiling the schema...
[xjc] Compiling file:/C:/Program
Files/JavaSoft/eclipse/workspace/semiJaxb/WEB-INF/src/semiG8 x/G81.xsd
[xjc] [WARNING] Unable to validate your schema. Most likely, the
JVM has loaded an incompatible XML parser implementation. You should fix
this before relying on the generated code. Please see the release notes
for details.
[xjc] unknown location
[xjc]
[xjc] BUILD FAILED: file:C:/Program
Files/JavaSoft/eclipse/workspace/semiJaxb/WEB-INF/src/semiG8 x/build.xml:32:
unable to parse the schema. Error messages should have been provided
Total time: 1 second
> generated classes.
> Steve
> > Darin
> > > strings.
I
Project"
or
"Eclipse
I
> > > STOPS!
> > > Tomcat Plugin 2.1.1
> > > Windows 2K
Re: Eclipse stops debugging with no errors [message #133593 is a reply to message #133041] Mon, 12 January 2004 11:42 Go to previous message
I suggest checking with the Sysdeo team. Since you are using the Sysdeo
launching support, we cannot claim responsibility for the problem.
Darin
news:btn5rk$k1q$1@eclipse.org...
> package?
> following error:
> compile:
> for details.
> [xjc]
to
The
second
> > generated classes.
I
and
> > Steve
unclear
> > > Darin
Plugin
needed
XML
> > > > strings.
section)
> I
through the
xml.
> Project"
reference
> or
> "Eclipse
and
> I
just
> > > > STOPS!
> > > > Tomcat Plugin 2.1.1
> > > > Windows 2K
Previous Topic:How to get enclosing classes to get inserted at END instead of START?
Next Topic:[ANN] JDK1.5 Plugin
Current Time: Wed Nov 05 00:46:24 EST 2025
Powered by FUDForum. Page generated in 0.05555 seconds
