Home » Eclipse Projects » Eclipse 4 » Best practise for using Translation Service (Luna M6)
Best practise for using Translation Service (Luna M6) [message #1318603] Sun, 27 April 2014 15:37 Go to next message
Hi all,
I'm looking for a practical way for the i18n of my application. I found
this blog post [1], but I think it could go easier. In my current
application (Eclipse 3.7 RCP) there I've a construction like this:
import static my.legacy.rcp.app.Translation._
(inside a method)
System.out.println(_("message.key"));
The "_" method is looking for the key and formats the message in the
right way.
I know that it's perhaps not the most optimal solution, but it worked
for now. If I want to use the TranslationService this construction fails
(or at least I don't know how to implement it), because there's no
static access to it. I want to use the "classic" way for my translation
files (OSGI-INF folder).
How could I get a similar solution in Eclipse 4 like the above mentioned?
Thanks in advance,
Ralf.
[1]
http://blog.vogella.com/2013/05/22/eclipse-internationalization-part-24-new-message-extension-by-dirk-fauth-and-tom-schindl/
Re: Best practise for using Translation Service (Luna M6) [message #1318734 is a reply to message #1318603] Sun, 27 April 2014 17:24 Go to previous messageGo to next message
The translation stuff in e4 uses methods instead of string literals
because this:
a) has less overhead from a memory point of view
b) is compiler checked
So your code would look like this:
@Inject
@Translation
Messages _;
System.out.println(_.message_key());
Tom
On 27.04.14 21:37, Ralf Heydenreich wrote:
> Hi all,
> (inside a method)
> right way.
> Thanks in advance,
> Ralf.
> [1]
Re: Best practise for using Translation Service (Luna M6) [message #1322280 is a reply to message #1318734] Tue, 29 April 2014 15:42 Go to previous messageGo to next message
Am 27.04.2014 23:24, schrieb Tom Schindl:
> because this:
> @Inject
> @Translation
> Messages _;
> Tom
Ok, I get it. Does it really mean that I have to maintain TWO files?
Then I have bundle_XX.properties and an accompanying Messages class
file... This cries for a little generator...
Greetz,
Ralf.
Re: Best practise for using Translation Service (Luna M6) [message #1323447 is a reply to message #1322280] Wed, 30 April 2014 05:03 Go to previous message
yes you need to maintain both
Tom
>> because this:
>> @Inject
>> @Translation
>> Messages _;
>> Tom
> Greetz,
> Ralf.
Previous Topic:EMenuService is null
Next Topic:labels in Application.e4xmi are not resolved
Current Time: Sat Jul 26 20:39:03 EDT 2025
Powered by FUDForum. Page generated in 0.05305 seconds
