Component visualization in VE [message #132233] |
Mon, 16 October 2006 08:25 |
Originally posted by: piotr.calko.pmpgroup.com
I have recently decided to create a new project based on another.
I copied all my old classes to the new project, but some of them I had to
reorganize into new packages. Both projects are now defined in Eclipse
3.2.0, but the old one was developed in 3.1.1. Java SDK version is 1.4.2.
The problem appears when I try to open a visual component class that
doesn't extend directly SWING's JComponent but its subclass written by me.
Visual Editor cannot visualize a form in right way. It displays exception
messages like those attached below.
Described problem appears ONLY in new project. Component visualization in
old one stayed OK. Cleaning the project, rebuilding, switching to other
version of Eclipse (3.1.1, 3.2.1) do not affect.
Is there a cure for that? Can anyone help?
Peter
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.NullPointerException: public java.awt.Point
org.eclipse.ve.internal.jfc.vm.ComponentManager.getDefaultLo cation()
at
org.eclipse.ve.internal.jfc.vm.ComponentManager.getDefaultLo cation(ComponentManager.java:1013)
at
org.eclipse.jem.internal.proxy.initParser.tree.ExpressionPro cesser.pushMethodInvocation(ExpressionProcesser.java:2605)
at
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.process(ExpressionProcesserController.java:284)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.p rocessExpressionCommand(ConnectionHandler.java:602)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:493)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
at
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:989)
at
org.eclipse.jem.internal.proxy.core.Expression.invokeExpress ion(Expression.java:685)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.getBeanPr opertyProxyValue(BeanProxyAdapter.java:1493)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.getBeanPr opertyValue(BeanProxyAdapter.java:1461)
at
org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:100)
at
org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:893)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:824 )
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1029)
at
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:943)
at
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:473)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
FUDForum. Page generated in 0.06237 seconds
