| Strange error message [message #131582] |
Wed, 10 August 2005 10:35  |
I have set up the web tools for the very first time - so apologies if
this is a dumb question.
I created a new "Dynamic Web Project" (using Tomcat 5.5 as the
applicatiopn server) and almost immediately got the warning below.
What am I missing and why?
IWAE0010E Run-time exception java.lang.NoSuchMethodError occurred during
validation. The validator being run was XML Validator and the message
thrown was
org.apache.xerces.xni.XMLResourceIdentifier.getNamespace()Lj ava/lang/String;.
| Re: Strange error message [message #132226 is a reply to message #132153] |
Fri, 12 August 2005 04:11   |
Originally posted by: alan.chandler.logicacmg.com
On Fri, 12 Aug 2005 00:23:02 -0400, "David Williams"
>> thrown was
>AFAIK, this is not a frequent problem (that I've heard), so besides Lawrence's suggestion to
>open a bugzilla giving detailed configuration information, I'll also suggest
>that you check if you have your own version of xerces installed in the
>your java's "endorced library" directory. Its a long shot, but I've seen one or two
>cases where people did that, following some directions the received from somewhere ...
>but they didn't really need to. [we include a xerces plugin with WTP, its version 2.7.0,
>and as far as we can tell is compatible with 1.4 and 1.5 versions of Java].
Searched all over in the various subdirectories under my Tomcat
installation and can't find anything.
| Re: Strange error message [message #146828 is a reply to message #131582] |
Fri, 11 November 2005 06:47  |
Originally posted by: hcukurtepe.gmail.com
i don't know whether it is solution or not but i had the same errors and i got rid of it by running validation while connected to internet.
FUDForum. Page generated in 0.50090 seconds
