Home » Eclipse Projects » Remote Application Platform (RAP) » M7 => Wrong Mouse X,Y
M7 => Wrong Mouse X,Y [message #132085] Sat, 09 May 2009 03:11 Go to next message
Mouse position on click on Browser is not correct.
Re: M7 => Wrong Mouse X,Y [message #132111 is a reply to message #132085] Sat, 09 May 2009 03:19 Go to previous messageGo to next message
Hi Walter,
in 1.2M7 we fixed a bug related to the same issue:
268235: [MouseEvents] Wrong mouse x,y coordinates
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268235
Why do you think that the mouse position is not correct? Can you provide
more details about your findings? Feel free to reopen the bug with a
snippet that demonstrate this issue.
Best,
Ivan
Re: M7 => Wrong Mouse X,Y [message #132130 is a reply to message #132111] Sat, 09 May 2009 10:25 Go to previous messageGo to next message
Sorry this is not M7 problem but occurs even on M6 on IE 8.
Works fine with Firefox though.
"Ivan Furnadjiev" <ivan@eclipsesource.com> wrote in message
news:gu3apo$ple$1@build.eclipse.org...
> Hi Walter,
> Best,
> Ivan
Re: M7 => Wrong Mouse X,Y [message #132180 is a reply to message #132130] Mon, 11 May 2009 06:08 Go to previous messageGo to next message
please file a bugzilla along with some code or easy steps that show
how to reproduce the problem
Rüdiger
>> Hi Walter,
>> provide more details about your findings? Feel free to reopen the bug
>> with a snippet that demonstrate this issue.
>> Best,
>> Ivan
Re: M7 => Wrong Mouse X,Y [message #133193 is a reply to message #132180] Sat, 16 May 2009 21:31 Go to previous messageGo to next message
The problem can be found by accessing www.propertymapz.com in IE 7 and IE 8
Steps to reproduced
Go to www.propertymapz.com
Maximize Zoom Level => Left click on the Map a Balloon appears in IE 7 &
FF at the correct location ( ie where the Mouse points ),
where as when using IE 8 the balloon appears at the wrong position (
sometimes you will never see the balloon as it is positioned outside the
view area ). The best way to get the balloon in IE 8 is to click towards
the left center.
Will provide the snippet when I get time.
Best Regards,
Walter G. Prabhakar.
"Rüdiger Herrmann" <rherrmann@eclipsesource.com> wrote in message
news:gu8tf2$c9p$1@build.eclipse.org...
> please file a bugzilla along with some code or easy steps that show how to
> Thanks
> Rüdiger
>>> Hi Walter,
>>> Best,
>>> Ivan
Re: M7 => Wrong Mouse X,Y [message #133969 is a reply to message #133193] Mon, 25 May 2009 07:35 Go to previous messageGo to next message
Walter,
we will have a look at this. As said, I bug entry would help to
track progress on this.
Rüdiger
> Steps to reproduced
> 7 & FF at the correct location ( ie where the Mouse points ),
> towards the left center.
> Best Regards,
>> Thanks
>> Rüdiger
>>>> Hi Walter,
>>>> bug with a snippet that demonstrate this issue.
>>>> Best,
>>>> Ivan
Re: M7 => Wrong Mouse X,Y [message #134005 is a reply to message #133193] Mon, 25 May 2009 10:54 Go to previous messageGo to next message
Hi Walter,
for me it's look like a Google map JS problem. Can you provide a RAP
standalone snippet (without Google map) that demonstrate the wrong mouse
coordinates problem in IE?
Best,
Ivan
> IE 8
> Steps to reproduced
> IE 7 & FF at the correct location ( ie where the Mouse points ),
> the view area ). The best way to get the balloon in IE 8 is to click
> Best Regards,
>> Thanks
>> Rüdiger
>>>> Hi Walter,
>>>> Best,
>>>> Ivan
Re: M7 => Wrong Mouse X,Y [message #134532 is a reply to message #134005] Sat, 30 May 2009 08:01 Go to previous message
Ivan, you are right, it is a bug in Google Map JS.
The workaround as mentioned in the Google site
http://code.google.com/p/gmaps-api-issues/issues/detail?id=1 055&q=apitype%3AJavascript&colspec=ID%20Type%20Statu s%20Introduced%20Fixed%20Summary%20Internal%20Stars
is to add
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />
Many thanks Ivan
- Walter.
news:gvebfd$ek8$1@build.eclipse.org...
> Hi Walter,
> Best,
> Ivan
>> 8
>> Steps to reproduced
>> Thanks,
>> Best Regards,
>>> Thanks
>>> Rüdiger
>>>>> Hi Walter,
>>>>> Best,
>>>>> Ivan
Previous Topic:Strange behavior of FilteredTree
Next Topic:Workspace & EFS
Current Time: Thu Jul 24 23:10:55 EDT 2025
Powered by FUDForum. Page generated in 0.10533 seconds
