Re: M7 => Wrong Mouse X,Y [message #133969 is a reply to message #133193] |
Mon, 25 May 2009 07:35   |
Walter,
we will have a look at this. As said, I bug entry would help to
track progress on this.
Rüdiger
Walter Prabhakar wrote:
> The problem can be found by accessing www.propertymapz.com in IE 7 and IE 8
> Steps to reproduced
> Go to www.propertymapz.com
> Maximize Zoom Level => Left click on the Map a Balloon appears in IE
> 7 & FF at the correct location ( ie where the Mouse points ),
> where as when using IE 8 the balloon appears at the wrong position (
> sometimes you will never see the balloon as it is positioned outside the
> view area ). The best way to get the balloon in IE 8 is to click
> towards the left center.
> Will provide the snippet when I get time.
> Best Regards,
> Walter G. Prabhakar.
> "Rüdiger Herrmann" <rherrmann@eclipsesource.com> wrote in message
> news:gu8tf2$c9p$1@build.eclipse.org...
>> please file a bugzilla along with some code or easy steps that show
>> how to reproduce the problem
>> Thanks
>> Rüdiger
>>> Sorry this is not M7 problem but occurs even on M6 on IE 8.
>>> Works fine with Firefox though.
>>> "Ivan Furnadjiev" <ivan@eclipsesource.com> wrote in message
>>> news:gu3apo$ple$1@build.eclipse.org...
>>>> Hi Walter,
>>>> in 1.2M7 we fixed a bug related to the same issue:
>>>> 268235: [MouseEvents] Wrong mouse x,y coordinates
>>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=268235
>>>> Why do you think that the mouse position is not correct? Can you
>>>> provide more details about your findings? Feel free to reopen the
>>>> bug with a snippet that demonstrate this issue.
>>>> Best,
>>>> Ivan
>>>>> Mouse position on click on Browser is not correct.
Re: M7 => Wrong Mouse X,Y [message #134005 is a reply to message #133193] |
Mon, 25 May 2009 10:54   |
Hi Walter,
for me it's look like a Google map JS problem. Can you provide a RAP
standalone snippet (without Google map) that demonstrate the wrong mouse
coordinates problem in IE?
Best,
Ivan
> IE 8
> Steps to reproduced
> IE 7 & FF at the correct location ( ie where the Mouse points ),
> the view area ). The best way to get the balloon in IE 8 is to click
> Best Regards,
>> Thanks
>> Rüdiger
>>>> Hi Walter,
>>>> Best,
>>>> Ivan
Re: M7 => Wrong Mouse X,Y [message #134532 is a reply to message #134005] |
Sat, 30 May 2009 08:01  |
Ivan, you are right, it is a bug in Google Map JS.
The workaround as mentioned in the Google site
http://code.google.com/p/gmaps-api-issues/issues/detail?id=1 055&q=apitype%3AJavascript&colspec=ID%20Type%20Statu s%20Introduced%20Fixed%20Summary%20Internal%20Stars
is to add
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />
Many thanks Ivan
- Walter.
news:gvebfd$ek8$1@build.eclipse.org...
> Hi Walter,
> Best,
> Ivan
>> 8
>> Steps to reproduced
>> Maximize Zoom Level => Left click on the Map a Balloon appears in IE 7
>> Thanks,
>> Best Regards,
>>> please file a bugzilla along with some code or easy steps that show how
>>> Thanks
>>> Rüdiger
>>>>> Hi Walter,
>>>>> provide more details about your findings? Feel free to reopen the bug
>>>>> Best,
>>>>> Ivan
FUDForum. Page generated in 0.04297 seconds
