Exception on delete from fully synchronised diagram [message #131760] |
Fri, 01 June 2007 04:58  |
Originally posted by: james.willans.xactium.com
We are hitting a strange bug with deleting a view element (node) using
"delete from model", the bug occurs when the same semantic element is also
viewed in another diagram (via CanonicalEditPolicy). The bug manifests
itself as the following Java exception:
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:1526)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1019)
at BS.impl.BS_ModelImpl.eGet(BS_ModelImpl.java:115)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1002)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:994)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:989)
at
BS.diagram.providers.BSStructuralFeatureParser.getStringByPa ttern(BSStructuralFeatureParser.java:81)
at
BS.diagram.providers.BSStructuralFeatureParser.getStringByPa ttern(BSStructuralFeatureParser.java:73)
at
BS.diagram.providers.BSAbstractParser.getPrintString(BSAbstr actParser.java:110)
at
BS.diagram.edit.parts.AssessmentAssessment_kindEditPart.getL abelText(AKEditPart.java:208)
at
BS.diagram.edit.parts.AssessmentAssessment_kindEditPart.refr eshLabel(AKEditPart.java:417)
I am presuming that the second diagram isn't aware that a delete is
occuring, and is therefore refreshing its label as a result of a model
change. The exception is thrown because eGet is supplied with a
StructuralFeature from a class other than that of the the object's it is
being called upon. At the other end of the exception "getLabelText" is
called on an editPart which comes about from a LabelMapping on a
NodeMapping in the GMF map model. It is that NodeMapping which is the
target of the "delete from model" in the generated implementation.
What seems to be happening is that resolveSemanticElement in the labels
editPart calls getElement() on its view. Rather than returning the
correct semantic element (of whose class the structural feature belongs),
ViewImpl::getElement() starts to ascend through the container hierarchy
because !isSetElement() returns true and produces the model element
underlying the top level diagram. The setting of the state associated
with isSetElement seems to happen earlier on in the delete process.
Can anyone shed any light on what might be going on here, and how best to
resolve it? I don't understand the usage of isSetElement (and its
associated state)? My best guess is that it is an ordering issue, but I
would appreciate some help figuring out how to fix it.
James
Re: Exception on delete from fully synchronised diagram [message #132266 is a reply to message #132067] |
Mon, 04 June 2007 07:46   |
Thanks Alex - I appreciate your help, could you give me a bit more
information. Here is what I know:
o The error occurs when two or more diagram on the same editing domain
contains a model element that is deleted from the one of the diagrams
using "delete from model". It doesn't occur with a single diagram,
therefore the error is caused by 2..n diagram
o That CanonicalEditPolicy is responsible for monitoring and
synchronisation changes that occur to the model which originated from
outside the diagram.
From what you have said, it seems that the model element view in the
second diagram is not getting removed as a result of the semantic element
deletion. This is entirely consistent with the error that I am seeing,
since the diagram editor is attempting to update a view which renders the
deleted semantic element. The CanonicalEditPolicy seems to have a
mechanism in place that deals with the removal of orphaned views in
refreshSemanticChildren(). Since this is not called during the "delete
from model", it suggest that the update which causes the exception is
being called before CanonicalEditPolicy::refresh() has taken placed?
The code you have pointed me to in ..BaseItemSemanticEditPolicy seems to
deal with the deletion of shortcuts. My understanding is that
..BaseItemSemanticEditPolicy creates requests and commands as a result of
user interaction with the diagram (whereas CanonicalEditPolicy does the
same for changes to the model outside of the diagram). So I'm confused:
o It doesn't seem logical to add further code to CanonicalEditPolicy,
since it seems to be doing its job, but it is not called in time.
..BaseItemSemanticEditPolicy since the problem occurs as a result of a
diagram not synchronising with its model, and this policy is doing a
different job.
Can you give me some guidance please? I have included the full exception
trace below.
James
Getting: 4 from: org.eclipse.emf.ecore.impl.EClassImpl@12e0e2f (name:
BS_Model) (instanceClassName: null) (abstract: false, interface: false)
eFeature: null
at
at
at
at
at
at
at
at
at
BS.diagram.edit.parts.AK_kindEditPart.getLabelText(AK_kindEd itPart.java:208)
at
BS.diagram.edit.parts.AK_kindEditPart.refreshLabel(AK_kindEd itPart.java:417)
at
BS.diagram.edit.parts.AK_kindEditPart.refreshVisuals(AK_kind EditPart.java:406)
at
BS.diagram.edit.parts.AK_kindEditPart.setLabel(AK_kindEditPa rt.java:170)
at BS.diagram.edit.parts.AKEditPart.addFixedChild(AKEditPart.ja va:128)
at BS.diagram.edit.parts.AKEditPart.addChildVisual(AKEditPart.j ava:153)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:197)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.addChild(GraphicalEditPart.java:1260)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$3(GraphicalEditPart.java:1)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt$3.run(GraphicalEditPart.java:829)
at
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:260)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refresh(GraphicalEditPart.java:819)
at
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
at
at
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refreshChild(GraphicalEditPart.java:1173)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.handleMajorSemanticChange(GraphicalEditPart.java:1199)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeEditPart.h andleNotificationEvent(ShapeEditPart.java:93)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPa rt.handleNotificationEvent(ShapeNodeEditPart.java:225)
at
BS.diagram.edit.parts.AKEditPart.handleNotificationEvent(AKE ditPart.java:260)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.notifyChanged(GraphicalEditPart.java:1379)
at
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.fireNotification(DiagramEventBroker.java:471)
at
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.resourceSetChanged(DiagramEventBroker.java:382)
at
org.eclipse.gmf.runtime.diagram.ui.internal.DiagramEventBrok erThreadSafe.resourceSetChanged(DiagramEventBrokerThreadSafe .java:72)
at
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain.postcommit(DiagramEditingDomainFac tory.java:213)
at
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.deactivate(TransactionalEditingDomainImpl.java:473)
at
org.eclipse.emf.transaction.impl.TransactionImpl.close(Trans actionImpl.java:530)
at
org.eclipse.emf.transaction.impl.TransactionImpl.commit(Tran sactionImpl.java:371)
at
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:138)
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:509)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:193)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
at
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.exe cute(DiagramAction.java:141)
at
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.doR un(DiagramAction.java:103)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.run(AbstractActionHandler.java:359)
at
org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run (ActionManager.java:225)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(A ctionManager.java:223)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.runWithEvent(AbstractActionHandler.java:377)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3490)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3104)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2264)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2228)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 03)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:457)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:452)
at com.xactium.bms.Application.start(Application.java:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1124)
at org.eclipse.equinox.launcher.Main.main(Main.java:1099)
A
Re: Exception on delete from fully synchronised diagram [message #132520 is a reply to message #132465] |
Mon, 04 June 2007 12:16  |
Hello James,
Can you please submitt a bugzilla entry describing exception - we should
remove it in any case...
> What I simply don't understand is how I can destroy views in other
> diagrams from a ???ItemSemanticEditpolicy. getDestroyElementCommand().
> As you say, a given diagram does not know about other diagrams sharing
> the EditingDomain.
There should be a central place dispatching the same editing domain for all
the diagrams (DocumentProvider ?). I suppose this place is a "knowledge holder",
so you can query it and get all the diagrams openned with this editing domain
now..
Alex Shatalin
FUDForum. Page generated in 0.12871 seconds
