Home » Eclipse Projects » Eclipse 4 » Eclipse 4 RCP application memory leakage
Eclipse 4 RCP application memory leakage [message #1320064] Mon, 28 April 2014 11:15 Go to next message
I've got an application, which seems to run fine, but the memory usage is not acceptable. The startup size is ~100MB. This stays the same, if I do nothing. But
if I move the Window around for a couple of seconds, it rises to around 200MB. Is there a common reason for this behavior?
Thanks for any advice!
Re: Eclipse 4 RCP application memory leakage [message #1320077 is a reply to message #1320064] Mon, 28 April 2014 11:20 Go to previous messageGo to next message
Make a heap-dump and compare the heap before and after the moving.
Tom
On 28.04.14 17:15, Private Name wrote:
> do nothing. But
Re: Eclipse 4 RCP application memory leakage [message #1320106 is a reply to message #1320077] Mon, 28 April 2014 11:42 Go to previous message
Okay, I used VisualVM to monitor the objects. When I sample the application I get a rising size for byte[] and int[].
At some point, it appears, garbage collection occurs and the used heap goes back to minimum. Before this points though
heapsize was increased, so the memory usage stays high.
How would I go further from here? byte and int could be anything, right?
Previous Topic:e4 View on compatibility layer in Luna
Next Topic:EMenuService is null
Current Time: Sun Jul 20 22:45:32 EDT 2025
Powered by FUDForum. Page generated in 0.02877 seconds
