Home » Modeling » OCL » Using 'literal value' elements in OCL expressions
Using 'literal value' elements in OCL expressions [message #1283504] |
Thu, 03 April 2014 09:48  |
I hope I'm not too vague with this:
Imagine I want to have a constraint on a class that specifies that an
integer typed property is smaller or bigger than some literal value:
self.age < 18
Now, rather than using the literal '18', our users would like to define
the value as a 'Literal Integer' element in the model. (In the UML tree
editor I do: Add child -> Packaged Element -> Literal Integer
So now, somewhere in my model there's a Literal Integer element named
'MY_LITERAL'.
Users would now like to use this in the expression:
self.age < MY_LITERAL
or maybe
self.age < the::namespace::MY_LITERAL
Is this a sound use case? I only talk about parsing the constraint, not
evaluating it.
Thanks for comments,
Felix
Re: Using 'literal value' elements in OCL expressions [message #1327615 is a reply to message #1283586] |
Fri, 02 May 2014 04:43   |
Hey Ed,
On 03/04/2014 17:39, Ed Willink wrote:
> Hi
> 'somewhere in my model ' is not a good place.
> UML models use Properties to host values by name within a Namespace
> hierarchy, so you should probably create a Class called e.g.
> GlobalConstants with a read-only (static) Property called MY_LITERAL.
If the user doesn't want to modify the model (let's not talk about that
...), do you think this would work:
I inject classifiers/static properties into the pivot representation:
For a given value defined in namespace some::prefix::MY_VALUE, I inject
a classifier 'some::prefix', with a static property 'MY_VALUE'. If
there's already a classifier with that qualified name, I just add the
property. If the property already exists, there's a conflict but I'll
just diss that case.
Objections?
In general, we were a bit surprised that UML offers a way to model a
value, yet there's no way to access that value in an OCL expression.
Felix
Re: Using 'literal value' elements in OCL expressions [message #1327683 is a reply to message #1327615] |
Fri, 02 May 2014 05:25   |
You have not yet explained where in your model you have a literal that
should be accessible but is not accessible.
You don't want to change your model but you are prepared to inject
things into it.
You seem to ignore my suggestion for static properties.
I'm very confused and so obviously cannot help.
Ed
On 02/05/2014 09:43, Felix Dorner wrote:
> Hey Ed,
>> Hi
> that ...), do you think this would work:
> inject a classifier 'some::prefix', with a static property 'MY_VALUE'.
> If there's already a classifier with that qualified name, I just add
> the property. If the property already exists, there's a conflict but
> I'll just diss that case.
> Objections?
> Felix
Re: Using 'literal value' elements in OCL expressions [message #1327747 is a reply to message #1327683] |
Fri, 02 May 2014 06:10   |
Yes, sorry. I attached a papyrus screenshot with a trivial example.
Package A contains a 'LiteralInteger' element. Sibling package B
contains a class 'Adult' with an Integer typed property 'age'. I would
like to say in OCL:
context Adult
self.age > A::MIN_AGE
From your first reply, I understand that this is not possible.
> things into it.
Only into the pivot presentation. The source model will stay untouched.
I love your suggestion, but the client doesn't want to change its
models. I don't want to bite the feeding hand and look for a 'workaround'.
That's why I want to add these fake classifiers with static properties
into the pivot representation. LiteralValues in the UML model would then
be accessible using static classifier property syntax, like the one above.
Hope things are more clear now.
Felix
>> Hey Ed,
>>> Hi
>> Objections?
>> Felix
Attachment: literal.png
(Size: 4.58KB, Downloaded 223 times)
Re: Using 'literal value' elements in OCL expressions [message #1327803 is a reply to message #1327747] |
Fri, 02 May 2014 06:46  |
For a name to be visible it must be in a namespace, such as a property
in a class or a class in a package. You can't just put junk anywhere and
expect that the 'name' property has your semantics.
Why can't you put your global constrants in a global package in a global
model. No need to chnage anything?
Ed Willink
> like to say in OCL:
> context Adult
>> things into it.
> 'workaround'.
> then be accessible using static classifier property syntax, like the
> one above.
> Felix
>>> Hey Ed,
>>>> Hi
>>> Objections?
>>> Felix
Current Time: Sun Jul 27 16:15:27 EDT 2025
Powered by FUDForum. Page generated in 0.03804 seconds
