Home » Eclipse Projects » Eclipse Platform » popup menu contribution for IProject type not showing up in Package Explorer
popup menu contribution for IProject type not showing up in Package Explorer [message #117442] Wed, 27 August 2003 13:03 Go to next message
Originally posted by: mpjohn.us.ibm.com
I have an Eclipse feature I've developed (using Eclipse 2.0.1) that I now
want to enhance with a popup menu item for resources of type IProject having
a particular nature. I've prototyped this popup menu by adding it to my
plugin.xml. I've defined a perspective for my feature that includes the
Navigator and Package Explorer Views. This new popup menu item works fine
in the Navigator View, but it doesn't even show up in the Package Explorer
View. Here's the object contribution XML:
<extension
id="com.ibm.jsdt.eclipse.ui.solutionMenu"
point="org.eclipse.ui.popupMenus">
<objectContribution
objectClass="org.eclipse.core.resources.IProject"
id="com.ibm.jsdt.eclipse.ui.solutionBuilder">
<filter
name="projectNature"
value="com.ibm.jsdt.eclipse.main.solutionProjectNature">
</filter>
<menu
label="Solution Enabler Tools"
path="addition"
id="com.ibm.jsdt.eclipse.ui.solutionMenu">
<separator
name="group1">
</separator>
</menu>
<action
label="Build Solution"
menubarPath="com.ibm.jsdt.eclipse.ui.solutionMenu/group1"
enablesFor="1"
id="com.ibm.jsdt.eclipse.ui.solutionBuilderAction">
</action>
</objectContribution>
</extension>
Related to the above, I've also added a menu item under the main "Project"
menu that is intended to perform the same action as the object contribution
above when a particular project type is selected. Again, the behavior
differs between the Navigator View and the Package Explorer View.
Everything works as expected in the Navigator View. In the Package Explorer
View, the submenu shows up under the "Project" menu, but the specific menu
item is disabled even when a project of the correct type is selected.
Here's the actionSets XML:
<extension
point="org.eclipse.ui.actionSets">
<actionSet
label="testplugin actionSet 5"
id="testplugin.actionSet5">
<menu id="testplugin.project.menu.se"
path="project/additions">
<separator name="group1"/>
</menu>
<action id="testplugin.buildsolution.action"
menubarPath="project/testplugin.project.menu.se/group1"
enablesFor="1">
<enablement>
<and>
<objectClass
name="org.eclipse.core.resources.IProject"/>
<objectState name="nature"
value="com.ibm.jsdt.eclipse.main.solutionProjectNature"/>
</and>
</enablement>
</action>
</actionSet>
</extension>
Can anyone help me figure out what I'm doing wrong?
Thanks.
Maynard
Re: popup menu contribution for IProject type not showing up in Package Explorer [message #123468 is a reply to message #117442] Fri, 05 September 2003 16:51 Go to previous messageGo to next message
Originally posted by: knut_radloff.oti.com
The menu path should be "additions", not "addition". Not sure if that'll solve your problem though.
Knut
"Maynard Johnson" <mpjohn@us.ibm.com> wrote in message news:biio9f$a7$1@eclipse.org...
> <extension
> <objectContribution
> <filter
> </filter>
> <menu
> path="addition"
> <separator
> name="group1">
> </separator>
> </menu>
> <action
> enablesFor="1"
> </action>
> </extension>
> <extension
> <actionSet
> </menu>
> enablesFor="1">
> <enablement>
> <and>
> <objectClass
> </and>
> </enablement>
> </action>
> </actionSet>
> </extension>
> Thanks.
> Maynard
Re: popup menu contribution for IProject type not showing up in Package Explorer [message #131949 is a reply to message #123468] Thu, 18 September 2003 09:13 Go to previous messageGo to next message
Thanks for the response, Knut. But apparently, that error in menu path
specification was being ignored by Eclipse and it was defaulting to
"additions" anyway. So, correcting that had no effect. However, I did find
a way to get this to work in the Package Explorer view -- by adding the
'adaptable="true"' attribute in the objectContribution. I have no idea why
this is needed for it to behave properly in Package Explorer, but not
Navigator, but it is.
"Knut Radloff" <knut_radloff@oti.com> wrote in message
news:bjasur$9vf$1@eclipse.org...
> Knut
now
having
fine
Explorer
> > <extension
> > <objectContribution
> > <filter
> > </filter>
> > <menu
> > path="addition"
> > <separator
> > name="group1">
> > </separator>
> > </menu>
> > <action
> > enablesFor="1"
> > </action>
> > </extension>
"Project"
contribution
Explorer
menu
> > <extension
> > <actionSet
> > </menu>
> > enablesFor="1">
> > <enablement>
> > <and>
> > <objectClass
> > </and>
> > </enablement>
> > </action>
> > </actionSet>
> > </extension>
> > Thanks.
> > Maynard
Re: popup menu contribution for IProject type not showing up in Package Explorer [message #132070 is a reply to message #131949] Thu, 18 September 2003 10:44 Go to previous message
Originally posted by: simon.ibm.oti.lab
It's because the project object you see in the package explorer is not an
IProject instance, but some other object. But this objecy "adapts" to
IProject, therefore the need for "adaptable=true"
Simon :-)
news:bkcb1e$dva$1@eclipse.org...
find
why
> > Knut
> now
> having
my
the
> fine
> Explorer
> > > <extension
> > > <objectContribution
> > > <filter
> > > </filter>
> > > <menu
> > > path="addition"
> > > <separator
> > > name="group1">
> > > </separator>
> > > </menu>
> > > <action
> > > enablesFor="1"
> > > </action>
> > > </extension>
> "Project"
> contribution
> Explorer
> menu
> > > <extension
> > > <actionSet
> > > </menu>
> > > enablesFor="1">
> > > <enablement>
> > > <and>
> > > <objectClass
> > > </and>
> > > </enablement>
> > > </action>
> > > </actionSet>
> > > </extension>
> > > Thanks.
> > > Maynard
Previous Topic:completing the install... - cannot replace splash screen bmp
Next Topic:Eclipse and Firewall
Current Time: Tue Jul 22 03:31:16 EDT 2025
Powered by FUDForum. Page generated in 0.13232 seconds
