Home » Language IDEs » C / C++ IDE (CDT) » How to set up makefile for use in CDT/Eclipse
How to set up makefile for use in CDT/Eclipse [message #131942] Thu, 16 December 2004 15:37 Go to next message
Originally posted by: smakam60540.yahoo.com
I just started using Eclipse for CDT. I installed CDT and MinGW files.
How do I configure Eclipse/CDT to create a makefile, specify external
libraries, specify external includes, build the code, and debug?
Things I have accomplished so far: Create a C++ project, import source
files, and specify MinGw-make.exe as the make tool in the make project
dialog box.
Thanks for your help!
Re: How to set up makefile for use in CDT/Eclipse [message #131989 is a reply to message #131942] Fri, 17 December 2004 03:03 Go to previous message
> dialog box.
Try to create a Managed Make C++ project, and make sure you go through
all the tabs in the New Project wizard, then in the projects properties
(righ click on the project root and choose properties) go in the section
C/C++ build, there you should see all the options you looking for.
PS: I'm using CDT 2.1RC6
Previous Topic:Install problems
Next Topic:How do I inspect unicode strings with CDT ?
Current Time: Fri Nov 07 09:03:19 EST 2025
Powered by FUDForum. Page generated in 0.03119 seconds
