Home » Eclipse Projects » JFace » TableViewer with OwnerDrawLabel only draws the first row
TableViewer with OwnerDrawLabel only draws the first row [message #1318306] Sun, 27 April 2014 11:36 Go to next message
This trivial test case running against Eclipse 4.3.2 puzzles me -- why is it that only the first row is drawn?
-S
---Begin---
package testcase;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.OwnerDrawLabelProvider;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Shell;
public class TableViewer_OwnerDrawLabel_Testcase {
		Display display = new Display();
		Shell shell = new Shell(display, SWT.SHELL_TRIM);
		shell.setLayout(new FillLayout());
		shell.setMinimumSize(600, 400);
		final TableViewer tv = new TableViewer(shell, SWT.BORDER | SWT.FULL_SELECTION);
		tv.setContentProvider(new IStructuredContentProvider() {
			public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
			public void dispose() {
			public Object[] getElements(Object inputElement) {
				return ((List)inputElement).toArray();
		tv.setLabelProvider(new OwnerDrawLabelProvider() {
			protected void paint(Event event, Object element) {
				GC gc = event.gc;
				gc.drawText((String)element, 0, 0, true);
			protected void measure(Event event, Object element) {
		ArrayList<String> items = new ArrayList<String>();
		items.add("one");
		items.add("two");
		items.add("three");
		tv.setInput(items);
		shell.pack();
		shell.open();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch()) {
				display.sleep();
---End---
[Updated on: Sun, 27 April 2014 11:37] by Moderator
Re: TableViewer with OwnerDrawLabel only draws the first row [message #1318514 is a reply to message #1318306] Sun, 27 April 2014 14:27 Go to previous messageGo to next message
Shouldn't you draw on event.x, event.y instead of 0,0? See
http://git.eclipse.org/c/platform/eclipse.platform.ui.git/tree/examples/org.eclipse.jface.snippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippets/viewers/Snippet010OwnerDraw.java
Tom
> -S
> ---Begin---
> package testcase;
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> @Override
> Object newInput) {
> @Override
> @Override
> @Override
> GC gc = event.gc;
> @Override
> items.add("one");
> items.add("two");
> items.add("three");
> tv.setInput(items);
> shell.pack();
> shell.open();
> display.sleep();
> ---End---
Re: TableViewer with OwnerDrawLabel only draws the first row [message #1318534 is a reply to message #1318514] Sun, 27 April 2014 14:43 Go to previous message
Thanks! that was it.
Previous Topic:[DATABINDING] How-to: binding the (current single) selection of treeViewers to something
Next Topic:TreeViewer::setInput() -> UI timeout
Current Time: Sun Jul 27 09:32:44 EDT 2025
Powered by FUDForum. Page generated in 0.03688 seconds
