Home » Archived » Test and Performance Tools Platform (TPTP) » Failed to launch latest eclipse 3.4 M6 build by Agent Controller + TPTP
Failed to launch latest eclipse 3.4 M6 build by Agent Controller + TPTP [message #131612] Tue, 24 June 2008 06:00 Go to next message
Originally posted by: ma_xiang1981.hotmail.com
I can launch eclipse 3.4 M5 successfully by Agent Controller + TPTP + jre
1.6.06. (TPTP version is 4.4.1), as following:
C:\mytest\org.eclipse.hyades.execution_4.4.100.v200802221314 >automation-client-adapter
-eclipse C:\eclipse-SDK-3.4M5-win32\eclipse -workspace C:\eclipseauto\final2
-project CR4EAutomationJUnitTest -suite
src\testcase\cr4e\sanity\CreateCRWebProject.testsuite -deployment
src\testcase\cr4e\sanity\SanityDeploy.deploy
But it failed when I trying to use TPTP and same Agent Controller to
launch eclipse 3.4 M6 RC4 build. Has any one also encountered the
following problem?
(1) If I tried to use the latest
org.eclipse.hyades.execution_4.4.200.v200806120100 package by installing
latest TPTP on line , I got the following error when launching eclipse:
IWAT0891E Unable to resolve service
'org.eclipse.hyades.test.tools.core.execute'
(2) If I use the original package, the error output is as following:
C:\mytest\org.eclipse.hyades.execution_4.4.100.v200802221314 >java-cp
/bin;tptp-automation-client.jar
org.eclipse.hyades.automation.client.adapters.shell.Automati onClientAdapter
-eclipse C:\eclipse-SDK-3.4RC1-win32\eclipse -workspace C:\eclipseauto\final2
šCproject CR4EAutomationJUnitTest -suite
java.lang.Exception
at org.eclipse.hyades.automation.server.ServiceProxy.<init>
ServiceProxy.java:100)
at
org.eclipse.hyades.automation.server.AutomationServer.run(Au tomationServer.java:254)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Re: Failed to launch latest eclipse 3.4 M6 build by Agent Controller + TPTP [message #131628 is a reply to message #131612] Tue, 24 June 2008 16:22 Go to previous messageGo to next message
Welkin wrote:
> Hello, I can launch eclipse 3.4 M5 successfully by Agent Controller +
> TPTP + jre 1.6.06. (TPTP version is 4.4.1), as following:
> C:\eclipseauto\final2 -project CR4EAutomationJUnitTest -suite
> following problem? (1) If I tried to use the latest
Did you install both the Platform and Testing packages? Or did you
install the All-in-one package?
Re: Failed to launch latest eclipse 3.4 M6 build by Agent Controller + TPTP [message #131639 is a reply to message #131628] Wed, 25 June 2008 01:55 Go to previous messageGo to next message
Hello, David
Thanks for reply. I use the following to configure the env:
eclipse-SDK-3.4RC4-win32.zip
dtp-sdk-1.6RC4-200806090500.zip
emf-sdo-xsd-SDK-2.4.0RC4.zip
GEF-ALL-3.4.0RC4.zip
wtp-sdk-S-3.0RC4-20080611064752.zip
TPTP
As for installing TPTP
(1)If I use tptp.sdk-TPTP-4.4.1.zip (All in one build in
http://www.eclipse.org/downloads/download.php?file=/tptp/4.4 .1/TPTP-4.4.1/tptp.sdk-TPTP-4.4.1.zip),
I will get the following error when launching eclipse:
java.lang.Exception
at
org.eclipse.hyades.automation.server.ServiceProxy.<init>(ServiceProxy.java:100)
at
(2)If I install latest TPTP on Ganymede update site
(http://download.eclipse.org/releases/ganymede) in eclipse ¡°Software
updates and add on¡± dialog, and select all under ¡°Testing and
Performance¡± for installation, as following:
TPTP log and trace Analyzer
TPTP Monitoring tools project
TPTP platform projects
TPTP profiling for web applications
TPTP projects examples
TPTP Reporting with BIRT
TPTP test framework and tools project
TPTP tracing and profiling tools project
'org.eclipse.hyades.test.tools.core.execute'.
I have not encountered this problem in eclipse 3.4 M5 build
Re: Failed to launch latest eclipse 3.4 M6 build by Agent Controller + TPTP [message #131650 is a reply to message #131628] Wed, 25 June 2008 02:03 Go to previous messageGo to next message
Hello,David
TPTP
(1) If I use tptp.sdk-TPTP-4.4.1.zip (All in one build in
java.lang.Exception
at
at
Re: Failed to launch latest eclipse 3.4 M6 build by Agent Controller + TPTP [message #131826 is a reply to message #131650] Thu, 26 June 2008 09:46 Go to previous message
Hi Welkin,
It appears that you are installing the TPTP 4.4.1 all-in-one driver with
the Ganymede dependnacies. Can you install the TPTP 4.5.0 (Ganymede)
all-in-one driver instead:
http://www.eclipse.org/tptp/home/downloads/?ver=4.5.0
As for installing from the Ganymede update site, I just verified that
this is working as designed. Please make sure you add the following
dependencies to the Ant classpath or lib directory before running:
-${tptp.automation.eclipse}\plugins\org.eclipse.hyades.execu tion_ <version>\ant-tptp.jar
Paul
"Welkin" <ma_xiang1981@hotmail.com> wrote in message
news:5ab2fbb5d52f260f6c283cafdb33d94d$1@www.eclipse.org...
> Hello,David
> TPTP
> http://www.eclipse.org/downloads/download.php?file=/tptp/4.4 .1/TPTP-4.4.1/tptp.sdk-TPTP-4.4.1.zip), I
> java.lang.Exception
> at
> at
Previous Topic:IWAT0284EThe agent controller is not available on host localhost.
Next Topic:How to develop an agent implementation which can be started by Agent Controller
Current Time: Sat Jul 26 08:08:38 EDT 2025
Powered by FUDForum. Page generated in 0.06064 seconds
