Problems installing and using Hudson 3.1.2 [message #1307106] |
Mon, 21 April 2014 06:42  |
While the hudson-3.1.2.war works fine with Tomcat 7.0.53 it does not work with Tomcat 8.0.5
The war deploys successfully but throws the following error message in the Tomcat Web Application Manager when attempting to start the app.
FAIL - Application at context path /hudson-3.1.2 could not be started
FAIL - Encountered exception org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/hudson-3.1.2]]
Of greater concern is the inability to install the Hudson-Eclipse integration from Sonatype to Eclipse (Kepler).
Attempting the Help -> Install New Software .. procedure as detailed in "The Hudson Book" in Eclipse (Kepler) throws the error
Cannot complete the install because one or more required items could not be found.
Software being installed: Hudson Integration for M2Eclipse 0.13.0.20111015-0033 (org.sonatype.m2e.hudson.feature.feature.group 0.13.0.20111015-0033)
Missing requirement: org.maven.ide.eclipse.ui.tests.common 1.1.7.201105091728 (org.maven.ide.eclipse.ui.tests.common 1.1.7.201105091728) requires 'bundle org.junit4 0.0.0' but it could not be found
Cannot satisfy dependency:
From: UI Commons 1.1.7.201105091728 (org.maven.ide.eclipse.commons.feature.feature.group 1.1.7.201105091728)
To: org.maven.ide.eclipse.ui.tests.common [1.1.7.201105091728]
From: Hudson Integration for M2Eclipse 0.13.0.20111015-0033 (org.sonatype.m2e.hudson.feature.feature.group 0.13.0.20111015-0033)
To: org.maven.ide.eclipse.commons.feature.feature.group [1.1.7.201105091728]
The procedure does however work flawlessly with Eclipse (Juno).
Googling the error suggests that a number of plugins have encountered this error. Unfortunately none of the workarounds detailed (e.g. placing the missing jar files in the Kepler plugins directory) seem effective in this case ?
Any alternative sources, workarounds or indication as to if and when Sonatype will address this issue?
FUDForum. Page generated in 0.15992 seconds
