Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] NullPointerException during merging
[EMF Compare] NullPointerException during merging [message #131634] Thu, 11 December 2008 08:14 Go to next message
Hi all,
today, I've explored the Compare project, which seems to be very easy
and helpfull, if one (like me) has to realize a comparison and merging
behavior. Thus, i tried to get it work, but it fails with a
NullPointerException during merge.
Both models are not conainted in a resource. They are created during
runtime and i have to put all elements, which currently not existing in
the right model (swapGradualTestingModel), from the left model
(testingModel).
The snippet i used was from the Eclipe Wiki:
try {
MatchModel match = MatchService.doContentMatch(this.testingModel,
this.swapGradualTestingModel, Collections.<String, Object> emptyMap());
// Computing differences
DiffModel diff = DiffService.doDiff(match, false);
// Merges all differences from model1 to model2
List<DiffElement> differences = new
ArrayList<DiffElement>(diff.getOwnedElements());
for(DiffElement el:differences){
System.out.println(el.getKind());
// MergeService.merge(differences, true);
} catch (ConcurrentModificationException e) {
e.printStackTrace();
} catch (InterruptedException e) {
The corresponding Exception trace:
at
org.eclipse.emf.compare.diff.merge.service.MergeFactory.getB estMerger(MergeFactory.java:111)
at
org.eclipse.emf.compare.diff.merge.service.MergeFactory.crea teMerger(MergeFactory.java:79)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.doMe rge(MergeService.java:170)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.merg e(MergeService.java:136)
at
org.eclipse.emf.compare.diff.merge.internal.impl.DiffGroupMe rger.undoInTarget(DiffGroupMerger.java:48)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.doMe rge(MergeService.java:172)
at
at
de.fraunhofer.fokus.testing.transformation.modelplex.sys2pit .Sys2PITTransformator.copyTemporaryTestContext2PIT(Sys2PITTr ansformator.java:155)
This is my first approach with EMF Compare, so may be, i didn't get the
main concepts.
Any ideas???
Thx
Timothy
Re: [EMF Compare] NullPointerException during merging [message #131648 is a reply to message #131634] Thu, 11 December 2008 08:21 Go to previous messageGo to next message
--------------000407090601050602010906
Hi Timothy,
This isn't a misunderstanding of EMF Compare but indeed an error from
our side. The merger expects each EObject to be contained within a
resource (we try and find the most appropriate merger for specific file
extensions, which are in turn retrieved from the resource). This will be
easily solved yet the CVS version has FIXes pending and isn't stable
enough to be built.
Could you raise a bugzilla for this issue? For now, the only workaround
I can suggest is for you to add the models in "dummy" resources in order
to merge. You can simply create "XMLResourceImpl" instances and add your
models' roots to their getContents() list. The resource itself doesn't
need to be saved, we only expect it to exist and have a non-null URI.
Sorry for the trouble
Laurent Goubet
Obeo
Timothy Marc a
Re: [EMF Compare] NullPointerException during merging [message #131658 is a reply to message #131648] Thu, 11 December 2008 15:05 Go to previous messageGo to next message
Originally posted by: tmothymarc.freenet.de
Dear Laurent,
okay, that could be a possibilty :) I tried it by inserting the model
into a dummy ressource, but it fails again with NPE.
Here's the snippet:
laurent Goubet schrieb:
> Hi Timothy,
> enough to be built.
> Laurent Goubet
> Obeo
> Timothy Marc a écrit :
>> Hi all,
>> in the right model (swapGradualTestingModel), from the left model
>> (testingModel).
>> try {
>> MatchModel match =
>> java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> the main concepts.
>> Any ideas???
>> Thx
>> Timothy
Re: [EMF Compare] NullPointerException during merging [message #131668 is a reply to message #131648] Thu, 11 December 2008 15:20 Go to previous messageGo to next message
Sorry, continuing the post :)
It works now... not as i want it to, but i think this is an logical
issue... if not, i will post again, be sure.
Can you give me an URL for the Bugzilla?
Timothy
Re: [EMF Compare] NullPointerException during merging [message #131678 is a reply to message #131668] Fri, 12 December 2008 04:10 Go to previous message
--------------020105070609040206060505
You can raise a bug here
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT against the
component "compare". We'll try to have the fix in the next integration
build.
Timothy Marc a
Re: [EMF Compare] NullPointerException during merging [message #620535 is a reply to message #131634] Thu, 11 December 2008 08:21 Go to previous message
Hi Timothy,
enough to be built.
Laurent Goubet
Obeo
Timothy Marc a
Re: [EMF Compare] NullPointerException during merging [message #620536 is a reply to message #131648] Thu, 11 December 2008 15:05 Go to previous message
Dear Laurent,
Here's the snippet:
> Hi Timothy,
> enough to be built.
> Laurent Goubet
> Obeo
>> Hi all,
>> (testingModel).
>> try {
>> MatchModel match =
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> the main concepts.
>> Any ideas???
>> Thx
>> Timothy
Re: [EMF Compare] NullPointerException during merging [message #620537 is a reply to message #131648] Thu, 11 December 2008 15:20 Go to previous message
Timothy
Re: [EMF Compare] NullPointerException during merging [message #620538 is a reply to message #131668] Fri, 12 December 2008 04:10 Go to previous message
build.
Timothy Marc a
Previous Topic:[EMF Compare] NullPointerException during merging
Next Topic:Loading a .emfdiff file
Current Time: Tue Jul 29 02:51:12 EDT 2025
Powered by FUDForum. Page generated in 0.08753 seconds
