Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] NullPointerException during merging
[EMF Compare] NullPointerException during merging [message #131634] |
Thu, 11 December 2008 08:14  |
Hi all,
today, I've explored the Compare project, which seems to be very easy
and helpfull, if one (like me) has to realize a comparison and merging
behavior. Thus, i tried to get it work, but it fails with a
NullPointerException during merge.
Both models are not conainted in a resource. They are created during
runtime and i have to put all elements, which currently not existing in
the right model (swapGradualTestingModel), from the left model
(testingModel).
The snippet i used was from the Eclipe Wiki:
try {
MatchModel match = MatchService.doContentMatch(this.testingModel,
this.swapGradualTestingModel, Collections.<String, Object> emptyMap());
// Computing differences
DiffModel diff = DiffService.doDiff(match, false);
// Merges all differences from model1 to model2
List<DiffElement> differences = new
ArrayList<DiffElement>(diff.getOwnedElements());
for(DiffElement el:differences){
System.out.println(el.getKind());
// MergeService.merge(differences, true);
} catch (ConcurrentModificationException e) {
e.printStackTrace();
} catch (InterruptedException e) {
The corresponding Exception trace:
at
org.eclipse.emf.compare.diff.merge.service.MergeFactory.getB estMerger(MergeFactory.java:111)
at
org.eclipse.emf.compare.diff.merge.service.MergeFactory.crea teMerger(MergeFactory.java:79)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.doMe rge(MergeService.java:170)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.merg e(MergeService.java:136)
at
org.eclipse.emf.compare.diff.merge.internal.impl.DiffGroupMe rger.undoInTarget(DiffGroupMerger.java:48)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.doMe rge(MergeService.java:172)
at
at
de.fraunhofer.fokus.testing.transformation.modelplex.sys2pit .Sys2PITTransformator.copyTemporaryTestContext2PIT(Sys2PITTr ansformator.java:155)
This is my first approach with EMF Compare, so may be, i didn't get the
main concepts.
Any ideas???
Thx
Timothy
Re: [EMF Compare] NullPointerException during merging [message #131658 is a reply to message #131648] |
Thu, 11 December 2008 15:05   |
Originally posted by: tmothymarc.freenet.de
Dear Laurent,
okay, that could be a possibilty :) I tried it by inserting the model
into a dummy ressource, but it fails again with NPE.
Here's the snippet:
laurent Goubet schrieb:
> Hi Timothy,
> This isn't a misunderstanding of EMF Compare but indeed an error from
> our side. The merger expects each EObject to be contained within a
> resource (we try and find the most appropriate merger for specific file
> extensions, which are in turn retrieved from the resource). This will be
> easily solved yet the CVS version has FIXes pending and isn't stable
> enough to be built.
> Could you raise a bugzilla for this issue? For now, the only workaround
> I can suggest is for you to add the models in "dummy" resources in order
> to merge. You can simply create "XMLResourceImpl" instances and add your
> models' roots to their getContents() list. The resource itself doesn't
> need to be saved, we only expect it to exist and have a non-null URI.
> Sorry for the trouble
> Laurent Goubet
> Obeo
> Timothy Marc a écrit :
>> Hi all,
>> in the right model (swapGradualTestingModel), from the left model
>> (testingModel).
>> try {
>> MatchModel match =
>> java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> the main concepts.
>> Any ideas???
>> Thx
>> Timothy
Re: [EMF Compare] NullPointerException during merging [message #620535 is a reply to message #131634] |
Thu, 11 December 2008 08:21  |
--------------000407090601050602010906
Hi Timothy,
enough to be built.
Laurent Goubet
Obeo
Timothy Marc a
Re: [EMF Compare] NullPointerException during merging [message #620536 is a reply to message #131648] |
Dear Laurent,
Here's the snippet:
> Hi Timothy,
> enough to be built.
> Laurent Goubet
> Obeo
>> Hi all,
>> (testingModel).
>> try {
>> MatchModel match =
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> the main concepts.
>> Any ideas???
>> Thx
>> Timothy
Current Time: Tue Jul 29 02:53:22 EDT 2025
Powered by FUDForum. Page generated in 0.06644 seconds
