Failed to launch latest eclipse 3.4 M6 build by Agent Controller + TPTP [message #131612] |
Tue, 24 June 2008 06:00  |
Originally posted by: ma_xiang1981.hotmail.com
I can launch eclipse 3.4 M5 successfully by Agent Controller + TPTP + jre
1.6.06. (TPTP version is 4.4.1), as following:
C:\mytest\org.eclipse.hyades.execution_4.4.100.v200802221314 >automation-client-adapter
-eclipse C:\eclipse-SDK-3.4M5-win32\eclipse -workspace C:\eclipseauto\final2
-project CR4EAutomationJUnitTest -suite
src\testcase\cr4e\sanity\CreateCRWebProject.testsuite -deployment
src\testcase\cr4e\sanity\SanityDeploy.deploy
But it failed when I trying to use TPTP and same Agent Controller to
launch eclipse 3.4 M6 RC4 build. Has any one also encountered the
following problem?
(1) If I tried to use the latest
org.eclipse.hyades.execution_4.4.200.v200806120100 package by installing
latest TPTP on line , I got the following error when launching eclipse:
IWAT0891E Unable to resolve service
'org.eclipse.hyades.test.tools.core.execute'
(2) If I use the original package, the error output is as following:
C:\mytest\org.eclipse.hyades.execution_4.4.100.v200802221314 >java-cp
/bin;tptp-automation-client.jar
org.eclipse.hyades.automation.client.adapters.shell.Automati onClientAdapter
-eclipse C:\eclipse-SDK-3.4RC1-win32\eclipse -workspace C:\eclipseauto\final2
šCproject CR4EAutomationJUnitTest -suite
java.lang.Exception
at org.eclipse.hyades.automation.server.ServiceProxy.<init>
ServiceProxy.java:100)
at
org.eclipse.hyades.automation.server.AutomationServer.run(Au tomationServer.java:254)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Re: Failed to launch latest eclipse 3.4 M6 build by Agent Controller + TPTP [message #131826 is a reply to message #131650] |
Thu, 26 June 2008 09:46  |
Hi Welkin,
It appears that you are installing the TPTP 4.4.1 all-in-one driver with
the Ganymede dependnacies. Can you install the TPTP 4.5.0 (Ganymede)
all-in-one driver instead:
http://www.eclipse.org/tptp/home/downloads/?ver=4.5.0
As for installing from the Ganymede update site, I just verified that
this is working as designed. Please make sure you add the following
dependencies to the Ant classpath or lib directory before running:
-${tptp.automation.eclipse}\plugins\org.eclipse.hyades.execu tion_ <version>\ant-tptp.jar
Paul
"Welkin" <ma_xiang1981@hotmail.com> wrote in message
news:5ab2fbb5d52f260f6c283cafdb33d94d$1@www.eclipse.org...
> Hello,David
> Thanks for reply. I use the following to configure the env:
> eclipse-SDK-3.4RC4-win32.zip
> dtp-sdk-1.6RC4-200806090500.zip
> emf-sdo-xsd-SDK-2.4.0RC4.zip
> GEF-ALL-3.4.0RC4.zip
> wtp-sdk-S-3.0RC4-20080611064752.zip
> TPTP
> As for installing TPTP
> (1) If I use tptp.sdk-TPTP-4.4.1.zip (All in one build in
> http://www.eclipse.org/downloads/download.php?file=/tptp/4.4 .1/TPTP-4.4.1/tptp.sdk-TPTP-4.4.1.zip), I
> will get the following error when launching eclipse:
> java.lang.Exception
> at
> org.eclipse.hyades.automation.server.ServiceProxy.<init>(ServiceProxy.java:100)
> at
FUDForum. Page generated in 0.05846 seconds
