| Home » Eclipse Projects » GEF » No more handles error [bug 53632]
 Goto Forum:|
| No more handles error [bug 53632] [message #131233] | Thu, 06 May 2004 14:46  |  |
| Eclipse User  |  |  |  |  | Originally posted by: phil.williams.toadmail.com
 All,
 After going through and plugging all my own leaks when creating SWT
 resources, I am still getting the dreaded no more handles error in my
 GEF-based plugin.  I am using 2.1.2 and have updated the draw2d jar that
 Pratik posted to bug 53632.  I have this error happening for several
 users on several different machines and configurations.
 In the last comment to this bug Randy mentions that this doesn't happen
 in 3.0 because there is better error handling.  Is it possible to get
 these into the 2.1.x stream?
 Also, I noticed that there are several open bugs on different causes of
 the "No more handles" error.  What is the best way to determine which
 effect I am seeing?  Obviously if I see draw2d in the stack, I know that
 it is this one.
 Phil
| Re: No more handles error [bug 53632] [message #131385 is a reply to message #131247] | Fri, 07 May 2004 19:35   |  |
| Eclipse User  |  |  |  |  | Originally posted by: gupolet.ulb.ac.be
 I had the same problem but usually it was a loop that never stopped. Also,
 I don't know what to do about that, but the paintFigure method is called
 way too often and so eats all the ressources. So far, the only solution I
 found was to put a sleep but it sure ain't great.
 Randy Hudson wrote:
 > You should report the conditions which cause this problem on the bugzilla.
 > Version 2.1.3 has been completed and tested by various GEF clients.  There
 > are no plans for a 2.1.4 at this point.  That doesn't mean that it won't
 > happen, but it is not scheduled.
 > You can try taking the code from HEAD and merging it into your own 2.1.x
 > version of the draw2d plug-in.  The affected class is
 > BufferedGraphicsSource.
 > "Phil Williams" <phil.williams@toadmail.com> wrote in message
 > news:c7e0qg$uoc$1@eclipse.org...
 > > All,
 > > it is this one.
 > > Thanks,
 > > Phil
| Re: No more handles error [bug 53632] [message #131433 is a reply to message #131385] | Sat, 08 May 2004 02:23   |  |
| Eclipse User  |  |  |  |  | Originally posted by: alex.weirig.telewalfer.lu
 I recently downloaded the Clay Database Modelling tool from Azzurri
 (www.azzurri.jp). Once I installed this plugin into both Eclipse 2.1.3
 and WSAD 5.1.1 and tried to create a new database model I got the "No
 more handles" exception.
 Since I tried this at the office, I use my regular userid. I then
 tried to do the same with my Windows Administrator userid and
 strangefully enough, everything worked just fine.
 After I created a new database model and left the GEF based model
 editor opened when closing Eclipse/WSAD, I was no longer able to
 restart Eclipse/WSAD with my regular userid because of the No handles
 exception.
 So it looks like the code that is executed could require some special
 access rights. If you work on your private PC you normally have all
 the rights, but on a corporate PC, based on your corporate security
 setting and constraints, your userid might not have all the necessary
 access rights.
 I have not been able to recreate the problem with my Administrator
 user, but with my normal user I get the problem each and every time.
 Maybe this can help tracking down what is happening.
 Alex
 PS: I'll be on holiday 'til next Thursday. So if I might not be able
 to reply to a follow up question. I will do so on Thursday of at the
 latest of Friday.
 >>>All,
 >>>it is this one.
 >>>Thanks,
 >>>Phil
| Re: No more handles error [bug 53632] [message #131532 is a reply to message #131433] | Mon, 10 May 2004 11:34   |  |
| Eclipse User  |  |  |  |  | Originally posted by: none.us.ibm.com
 It could be another application which is associated with a specific account
 is causing a side-effect.
 "Alex Weirig" <alex.weirig@telewalfer.lu> wrote in message
 news:c7htv9$28t$1@eclipse.org...
 > Hello,
 > exception.
 > access rights.
 > Alex
 > latest of Friday.
 Also,
 I
 bugzilla.
 There
 > >>>All,
 that
 that
 > >>>it is this one.
 > >>>Thanks,
 > >>>Phil
| Re: No more handles error [bug 53632] [message #131544 is a reply to message #131385] | Mon, 10 May 2004 11:37  |  |
 Which platform?  What do you mean it is called too often?
 "Guillaume" <gupolet@ulb.ac.be> wrote in message
 news:c7h6gg$g9r$1@eclipse.org...
 bugzilla.
 There
 > > > All,
 that
 happen
 of
 that
 > > > it is this one.
 > > > Thanks,
 > > > Phil
 Current Time: Fri Oct 31 02:52:31 EDT 2025
 Powered by FUDForum . Page generated in 0.03020 seconds |
