Home » Modeling » TMF (Xtext) » Headless testing for xtext(Headless testing for xtext)
icon5.gif  Headless testing for xtext [message #1292297] Fri, 11 April 2014 13:57 Go to next message
Hi all,
I was trying out for headless testing for my code generators in my xtext project.
To begin with, I just created a java class (which is not present in ....tests project generated by xtext), Injected the injector and did emf registration. I have written a method (Say method name "callGenerators()") where my generators are called in the same class. And from the main method of this class I am trying to call this method i.e callGenerators(). But It doesn't look like all the injections have been injected properly. My injector, resourceset everything is null. But when I write the same code in JUNIT class then it works fine.
And I will execute this class from the command prompt for my headless testing.
This was just a try. Is this the right approach that I followed? Any further configurations needs to be done?
Or can someone tell me how to start with it if I am wrong.
Thanks in advance Smile
Re: Headless testing for xtext [message #1292437 is a reply to message #1292297] Fri, 11 April 2014 16:28 Go to previous messageGo to next message
can you please share code and exact steps to reproduce
Re: Headless testing for xtext [message #1312751 is a reply to message #1292297] Thu, 24 April 2014 09:28 Go to previous message
Did you use create a Injector? The standaloneSetup of a language can
create an injector or you can create a separated one for the generator.
The generator should be instantiated only through an injector. Otherwise
the injection will never work. May be you should have a look at
http://www.xpect-tests.org/ which handles generator tests in an easy way.
Holger
On 11.04.14 19:57, Arshad Adavani wrote:
> Hi all,
> project.
> testing.
> Thanks in advance :)
Previous Topic:How to extend xbase::XBlockExpression?
Next Topic:Typesystem for own DSL
Current Time: Sun Jul 27 22:28:24 EDT 2025
Powered by FUDForum. Page generated in 0.05803 seconds
