Home » Modeling » TMF (Xtext) » Resolve Proxies during linking phase
Resolve Proxies during linking phase [message #1312400] Thu, 24 April 2014 05:10 Go to next message
we defined a DSL that supports a "templating" mechanism like:
TEMPLATE t
ATTRIBUTE a1
ATTRIBUTE a2
ENTITY e1 FROM t
ENTITY e2 FROM t
During the linking phase, our linker copies the "ATTRIBUTE"-elements from the templates to the entities and the code generators work on a model that was modified this way.
Now we have a problem, when template and entity are defined in different resources:
Resource r1 contains
TEMPLATE t
ATTRIBUTE a1
ATTRIBUTE a2
Resource r2 contains
ENTITY e1 FROM t
When the linker processes r2 the template t is a proxy object and we have no idea how to resolve this proxy to copy the attributes.
Is there any way to get the "ATTRIBUTE"-elements of t when linking r2?
regards
Norman
Re: Resolve Proxies during linking phase [message #1312742 is a reply to message #1312400] Thu, 24 April 2014 09:23 Go to previous messageGo to next message
did you consider to use IDerivedStateComputer instead http://xtextcasts.org/episodes/18-model-optimization
or you copy the proxies to.
[Updated on: Thu, 24 April 2014 09:23] by Moderator
Re: Resolve Proxies during linking phase [message #1312743 is a reply to message #1312400] Thu, 24 April 2014 09:22 Go to previous messageGo to next message
I am afraid that resolving crossrefs during linking is not a good Idea
since you may run into a chicken egg problem. Using the URI of the proxy
and try to resolve against the resources ResourceSet may lead to cycles.
Anyway - why don't you use a postprocessor after linking has been done.
Holger
On 24.04.14 14:50, Norman Lenzner wrote:
> TEMPLATE t
> ATTRIBUTE a1
> ATTRIBUTE a2
> ENTITY e1 FROM t
> ENTITY e2 FROM t
> resources:
> TEMPLATE t
> ATTRIBUTE a1
> ATTRIBUTE a2
> ENTITY e1 FROM t
> regards
> Norman
Re: Resolve Proxies during linking phase [message #1312752 is a reply to message #1312742] Thu, 24 April 2014 09:29 Go to previous messageGo to next message
Christian is absolutely right. Missed that one. ;-)
On 24.04.14 15:23, Christian Dietrich wrote:
Re: Resolve Proxies during linking phase [message #1312904 is a reply to message #1312742] Thu, 24 April 2014 11:25 Go to previous message
thanks for the link, it works Smile
Christian Dietrich wrote on Thu, 24 April 2014 09:23
did you consider to use IDerivedStateComputer instead [link-not-allowed]
Previous Topic:Typesystem for own DSL
Next Topic:Integrate xml into my dsl ('hidden' transformation)
Current Time: Sat Jul 26 12:46:26 EDT 2025
Powered by FUDForum. Page generated in 0.08757 seconds
