Home » Archived » Hudson » Hudson slaves killed (3.1.2 update)
Hudson slaves killed (3.1.2 update) [message #1310460] Wed, 23 April 2014 03:42 Go to next message
I've tried to install Hudson 3.1.2, but since this update, our slaves died after each build.
Our Hudson configuration uses two slaves (one on Linux, one on Windows), and both of them is killed each time a build is launched on it. The build is not even performed. For information, the slaves are connected using the JNLP mechanism.
When the slave executor thread is killed, I have the following stack trace :
com.google.common.util.concurrent.UncheckedExecutionException: java.lang.NullPointerException
	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2263)
	at com.google.common.cache.LocalCache.get(LocalCache.java:4000)
	at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:4004)
	at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4874)
	at hudson.model.RunMap$LazyRunValueCache.get(RunMap.java:793)
	at hudson.model.RunMap$LazyRunValueCache.access$1900(RunMap.java:736)
	at hudson.model.RunMap$LazyRunValue.getBuild(RunMap.java:1559)
	at hudson.model.RunMap$4.apply(RunMap.java:545)
	at hudson.model.RunMap$4.apply(RunMap.java:541)
	at com.google.common.collect.Lists$TransformingRandomAccessList.get(Lists.java:575)
	at java.util.AbstractList$Itr.next(Unknown Source)
	at hudson.model.Job.getEstimatedDuration(Job.java:1317)
	at hudson.model.queue.MappingWorksheet.<init>(MappingWorksheet.java:353)
	at hudson.model.queue.MappingWorksheet.<init>(MappingWorksheet.java:335)
	at hudson.model.Queue.maintain(Queue.java:990)
	at hudson.model.Queue.pop(Queue.java:817)
	at hudson.model.Executor.grabJob(Executor.java:188)
	at hudson.model.Executor.run(Executor.java:113)
	at hudson.model.RunMap$LazyRunValueCache$1.load(RunMap.java:776)
	at hudson.model.RunMap$LazyRunValueCache$1.load(RunMap.java:770)
	at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3599)
	at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2379)
	at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2342)
	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2257)
	... 17 more
The master is also killed at the same time with the following stack trace :
Do you have any idea on how I can correct this ? May I must downgrade to 3.1.1 ? Or it's because of one of my installed plugins ?
[Updated on: Wed, 23 April 2014 03:44] by Moderator
Re: Hudson slaves killed (3.1.2 update) [message #1310644 is a reply to message #1310460] Wed, 23 April 2014 05:58 Go to previous messageGo to next message
Resolved ! Very Happy
The problem was not due to the new Hudson version, but to how we have made the update.
Indeed, after a first step to update Hudson to 3.1.2, we have installed the plugin 'Build Pipeline Plugin' to evaluate it, but this causes some errors (don't known why). Thus, we have uninstalled it and made a backup restoration.
But, as some builds have been done since the last backup, the files '_runmap.xml' located in the directory of the job executed on the slaves were corrupted by the new builds : they were containing two <build> with the same identifier, as the restoration reverted the also next build number... After deleting the duplicated builds in '_runmap.xml', and correcting the next build number, the slaves reacts correctly.
Re: Hudson slaves killed (3.1.2 update) [message #1311323 is a reply to message #1310644] Wed, 23 April 2014 14:42 Go to previous message
Hi Jonathan, do you happened to have the full Hudson & Slave log when the issue happened. It would help us to figure out why the failure was not handled gracefully.
Previous Topic:Accept pull request with GitLab repo viewer for git plugin
Next Topic:Plugin NoClassDefFoundError
Current Time: Wed Jul 23 01:49:25 EDT 2025
Powered by FUDForum. Page generated in 0.07979 seconds
