Home » Eclipse Projects » e(fx)clipse » Opening a dialog from within a dialog(working with multiple dialogs)
Opening a dialog from within a dialog [message #1309448] Tue, 22 April 2014 14:05 Go to next message
I create a dialog that opens from a menu click. There is a button on the dialog that when clicked, opens a second dialog. It works but it places the second dialog behind the first and it isn't visible. Is there a way to make the second dialog come to the front?
Re: Opening a dialog from within a dialog [message #1309479 is a reply to message #1309448] Tue, 22 April 2014 14:30 Go to previous messageGo to next message
Well you probably want to pass the current dialog as the parent but
without showing us your current code I can't give you a better info.
Tom
Re: Opening a dialog from within a dialog [message #1309504 is a reply to message #1309479] Tue, 22 April 2014 14:47 Go to previous messageGo to next message
I thought of that but the efxclipse dialog class constructor requires the first argument to be the parent window and complains when I pass it the dialog as the parent. (MessageDialog extends Dialog)
Here is my code:
public MessageDialog(Window parent, String title) {
super(parent, title);
Re: Opening a dialog from within a dialog [message #1309518 is a reply to message #1309504] Tue, 22 April 2014 14:57 Go to previous messageGo to next message
So you pass null?
You should get access to the window e.g. of the button by calling
button.getScene().getWindow() and pass that.
Tom
> Here is my code:
> super(parent, title); }
Re: Opening a dialog from within a dialog [message #1309532 is a reply to message #1309518] Tue, 22 April 2014 15:09 Go to previous message
Tom,
You are a genius! Thanks! Very Happy
Previous Topic:problem installing e(fx)clipse on my JUNO
Next Topic:javaFX in e4 vs Java application
Current Time: Mon Jul 21 02:45:14 EDT 2025
Powered by FUDForum. Page generated in 0.07112 seconds
