Home » Modeling » Epsilon » [EVL] conditional syntax
[EVL] conditional syntax [message #1308921] Tue, 22 April 2014 07:02 Go to next message
Say I have a rough emfatic file like this,
class Block {
//Node
class A extends Block { }
//Node
class B extends Block { }
//Node
class C extends Block { }
//Link
class connect{
ref Block target;
ref Block source;
All i want to validate in EVL is ...
context connect
if ( source instanceof A & target instanceof B ) {
message : "This is discouraged!"
else if ( source instanceof C & target instanceof B ) {
message : "This is encouraged!"
Kindly help me with the evl syntax!
Shrikanth NC
Re: [EVL] conditional syntax [message #1308922 is a reply to message #1308921] Tue, 22 April 2014 07:05 Go to previous messageGo to next message
Please refer to the isTypeOf/isKindOf operations in the Epsilon book.
Dimitris
Re: [EVL] conditional syntax [message #1308949 is a reply to message #1308922] Tue, 22 April 2014 07:24 Go to previous messageGo to next message
It does work as intended. ( when i use either isKindOf/isTypeOf )
But there is a side effect.
Like if I connect A to A or B to B or A to C
then in this case both messages are shown with error!
My Evl below,
context connect{
constraint DiscouragedUsage1{
check : self.source.isKindOf(A) and self.target.isKindOf( B)
message : "This is discouraged usage 1!"
constraint DiscouragedUsage2{
check : self.source.isKindOf(B) and self.target.isKindOf( C)
message : "This is discouraged usage 2!"
Shrikanth NC
[Updated on: Tue, 22 April 2014 07:26] by Moderator
Re: [EVL] conditional syntax [message #1309039 is a reply to message #1308949] Tue, 22 April 2014 08:33 Go to previous messageGo to next message
Could you please put together a minimal example [1] I can use to reproduce this?
Dimitris
[1] http://eclipse.org/epsilon/doc/articles/minimal-examples/
Re: [EVL] conditional syntax [message #1310259 is a reply to message #1309039] Wed, 23 April 2014 01:01 Go to previous messageGo to next message
mailed to epsilon.devs@gmail.com <epsilon.devs@gmail.com>;
Shrikanth NC
Re: [EVL] conditional syntax [message #1312444 is a reply to message #1310259] Thu, 24 April 2014 05:42 Go to previous messageGo to next message
Apologies for the slow response. In EVL, validation errors are produced when check condition are *not* satisfied. As such, you'll need to express your constraints as follows:
context Connect{
check : not (self.source.isKindOf(A) and self.target.isKindOf( B ))
check : not (self.source.isKindOf(A) and self.target.isKindOf( C ))
Dimitris
Re: [EVL] conditional syntax [message #1313739 is a reply to message #1312444] Thu, 24 April 2014 22:08 Go to previous message
Fine. Got it!
Shrikanth NC
Previous Topic:Problems using HUTN with Epsilon
Next Topic:GMF node disappears
Current Time: Sun Jul 20 22:05:32 EDT 2025
Powered by FUDForum. Page generated in 0.17640 seconds
