Home » Eclipse Projects » e(fx)clipse » problem following e(fx)clipse tutorial 1 step 9(error during the tryout)
problem following e(fx)clipse tutorial 1 step 9 [message #1308041] Mon, 21 April 2014 19:15 Go to next message
I use Eclipse 4.3.2 downloaded from http://efxclipse.bestsolution.at/install.html . I also use Java 7
Java(TM) SE Runtime Environment (build 1.7.0_55-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.55-b03, mixed mode)
When I follow the tutorial 1, on step 9, highlight the MyApplication.java and click "run", I get this following error. I am using Redhat 5.8 and it seems this is NOT supported in this version of RedHat?
prism ES2 Error - nInitialize: glXChooseFBConfig failed
Exception in thread "main" java.lang.RuntimeException: java.lang.UnsatisfiedLinkError: /usr/java/jdk1.7.0_55/jre/lib/amd64/libglass.so: libgio-2.0.so.0: cannot open shared object file: No such file or directory
at com.sun.javafx.tk.quantum.QuantumToolkit.startup(QuantumToolkit.java:284)
at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:127)
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:163)
at com.sun.javafx.application.LauncherImpl.access$000(LauncherImpl.java:47)
at com.sun.javafx.application.LauncherImpl$1.run(LauncherImpl.java:115)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.UnsatisfiedLinkError: /usr/java/jdk1.7.0_55/jre/lib/amd64/libglass.so: libgio-2.0.so.0: cannot open shared object file: No such file or directory
Re: problem following e(fx)clipse tutorial 1 step 9 [message #1308598 is a reply to message #1308041] Tue, 22 April 2014 02:42 Go to previous messageGo to next message
This does look like a JavaFX problem and nothing we can fix for you. Try
asking at the Oracle JavaFX forum or file a bug report.
Tom
On 22.04.14 01:15, David W wrote:
> Hi
> RedHat?
> at
> at
> at
> at
> at
Re: problem following e(fx)clipse tutorial 1 step 9 [message #1309809 is a reply to message #1308598] Tue, 22 April 2014 18:55 Go to previous messageGo to next message
Hi Tom
Thanks, what I found is that JavaFX 2 (from Java 7) does NOT support Redhat 5. Therefore, I just installed the windows version of Java 7 and the Eclipse Kepler . I tried the tutorial again and this time, it goes further. However, when I tried step 11 to build the jar file, Eclipse gives some error like
BUILD FAILED
C:\JavaProj\JavaFX\build\build.xml:53: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files\Java\jre7"
Re: problem following e(fx)clipse tutorial 1 step 9 [message #1309828 is a reply to message #1309809] Tue, 22 April 2014 19:06 Go to previous messageGo to next message
Ok, I got it. Here is the trick
Go to computer properties, advanced system settings, advanced, environment variables
Add a system variable called "JAVA_HOME" set its folder to the JDK location in my case "C:\Program Files\Java\jdk1.7.0_55"
However, I got a new problem, that is the following error
BUILD FAILED
C:\JavaProj\JavaFX\build\build.xml:87: Problem: failed to create task or type javafx:com.sun.javafx.tools.ant:resources
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken place.
No types or tasks have been defined in this namespace yet
and I checked more, I found the cause is
Could not load definitions from resource com/sun/javafx/tools/ant/antlib.xml. It could not be found.
[Updated on: Tue, 22 April 2014 19:15] by Moderator
Re: problem following e(fx)clipse tutorial 1 step 9 [message #1310415 is a reply to message #1309828] Wed, 23 April 2014 03:05 Go to previous messageGo to next message
It looks like it can not find the additional task-defs. I think the
problem is still that it tries to run the build with the JRE instead of
the JDK.
You are better of registering your JDK inside Eclipse you find them in
your preferences Java > Installed JREs and afterwards set the JDK on
your project instead of the JRE it is currently associated with.
Tom
> However, I got a newer problem, that is the following error
> BUILD FAILED
> place.
Re: problem following e(fx)clipse tutorial 1 step 9 [message #1313666 is a reply to message #1310415] Thu, 24 April 2014 21:09 Go to previous messageGo to next message
Hi Tom
I tried it. but still getting
init-fx-tasks:
[taskdef] Could not load definitions from resource com/sun/javafx/tools/ant/antlib.xml. It could not be found.
Strange, is there anything else?
Re: problem following e(fx)clipse tutorial 1 step 9 [message #1314106 is a reply to message #1313666] Fri, 25 April 2014 03:01 Go to previous messageGo to next message
Can you give me your exact env? So that I can try to reproduce.
Tom
On 25.04.14 03:09, David W wrote:
> Hi Tom
> init-fx-tasks:
Re: problem following e(fx)clipse tutorial 1 step 9 [message #1506200 is a reply to message #1314106] Wed, 10 December 2014 12:09 Go to previous messageGo to next message
Hi!
I have similar problem. What is the correct solution of this problem?
Re: problem following e(fx)clipse tutorial 1 step 9 [message #1507825 is a reply to message #1506200] Thu, 11 December 2014 19:05 Go to previous message
So you have oraclejdk8 installed? What jvm is used to launch the build? Screenshots would help
Previous Topic:Table column and composition relation binding
Next Topic:Problem with the "ambitious" installation
Current Time: Tue Sep 16 21:30:22 EDT 2025
Powered by FUDForum. Page generated in 1.05722 seconds
