Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] About MatchService API.
[EMF Compare] About MatchService API. [message #130478] |
Tue, 28 October 2008 14:29  |
Hi guys,
I was wondering about the use of the EMF Compare API, because I have
encountered some problems with it.
I have simply coded an action to compare two EObjects, and to open an
editor with the differences.
Having the case that I have 2 identical models, if I run the action
between the 2 root eObjects of both models, all works fine as expected,
with 0 differences in the compare editor. However if I try to compare
the two same children of the root eObjects in both models, the compare
editor is opened with 1 difference. Besides, if I explore the
differences, a NPE is thrown.
I'm not sure if it's a bug, or I'm not correctly using the API.
This is way I'm using the EMF Compare API:
// Computing the match
HashMap<String, Object> options = new HashMap<String, Object>();
options.put(MatchOptions.OPTION_IGNORE_XMI_ID, Boolean.TRUE);
options.put(MatchOptions.OPTION_PROGRESS_MONITOR, monitor);
MatchModel match = MatchService.doContentMatch(jobEObject1, jobEObject2,
options);
// Computing differences
DiffModel diff = DiffService.doDiff(match, false);
// We create the snapshot
ModelInputSnapshot snapshot =
DiffFactory.eINSTANCE.createModelInputSnapshot();
snapshot.setDiff(diff);
snapshot.setMatch(match);
// We open the Editor.
ModelCompareEditorInput editorInput = new
ModelCompareEditorInput(snapshot);
CompareUI.openCompareEditorOnPage(editorInput, page);
Below, The NPE thrown, while exploring the unexpected difference in the
editor.
Adolfo.
at
org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(C omposedAdapterFactory.java:340)
at
org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(C omposedAdapterFactory.java:277)
at org.eclipse.emf.compare.util.AdapterUtils.adapt(AdapterUtils .java:55)
at
org.eclipse.emf.compare.util.AdapterUtils.getItemProviderTex t(AdapterUtils.java:110)
at
org.eclipse.emf.compare.diff.provider.MoveModelElementItemPr ovider.getText(MoveModelElementItemProvider.java:110)
at
org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider .getText(AdapterFactoryLabelProvider.java:374)
at
org.eclipse.emf.compare.ui.viewer.structure.ModelStructureMe rgeViewer$ModelStructureLabelProvider.getText(ModelStructure MergeViewer.java:333)
at
org.eclipse.jface.viewers.WrappedViewerLabelProvider.getText (WrappedViewerLabelProvider.java:108)
at
org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:164)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:932)
at
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:102)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:1012)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2041)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:827)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:802)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:634)
at
org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1442)
at
org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:927)
at
org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1453)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:126)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7306)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4718)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:17 56)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4348)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3841 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4528 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:227 4)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1529)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:6249)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3822 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5791)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4541 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:23 71)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3420)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Re: [EMF Compare] About MatchService API. [message #130491 is a reply to message #130478] |
Tue, 28 October 2008 14:33   |
BTW,
I have tried with the last emf.compare code from CVS, and it doesn't
work neither.
Adolfo.
Adolfo Sánchez-Barbudo Herrera escribió:
> Hi guys,
> options);
> editor.
> Cheers,
> Adolfo.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [EMF Compare] About MatchService API. [message #130531 is a reply to message #130518] |
Wed, 29 October 2008 10:43   |
Ok Laurent,
The problem occurs always (the examples I have tried), independtly the
model and metamodel. So I have prepared a simple example with two very
simple UML models.
I think that it's an implementation bug so I'll better raise a bugzilla,
attaching a zip with the two simple models, and the correspondent diff
models generated by the comparison.
Adolfo.
laurent Goubet escribió:
> Hi Adolfo,
> The NPE I can easily fix, but that wouldn't help with the root problem :
> could you send me the models you compare or the result of the comparison
> either here or via mail laurent (dot) goubet (at) obeo (dot) fr so that
> I can try and see why we detected a diff? As for the NPE, it should be
> fixed in the next build.
> Regards
> Laurent Goubet
> Obeo
> Adolfo Sánchez-Barbudo Herrera a écrit :
>> BTW,
>> work neither.
>> Cheers,
>> Adolfo.
>>> Hi guys,
>>> expected, with 0 differences in the compare editor. However if I try
>>> to compare the two same children of the root eObjects in both models,
>>> the compare editor is opened with 1 difference. Besides, if I explore
>>> the differences, a NPE is thrown.
>>> jobEObject2, options);
>>> the editor.
>>> Cheers,
>>> Adolfo.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: [EMF Compare] About MatchService API. [message #130559 is a reply to message #130545] |
Wed, 29 October 2008 11:09   |
> Adolfo,
> Yes, that would be nice :). And I am sure not to forget about it lying
> in the mails :).
Hahahahaha... I just like having a track of the problems which I detect
around Eclipse's projects, and bugzilla is the a lovely place to do that :D
I have already risen the bug ->
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252599 ;)
Adolfo.
> Laurent Goubet
> Obeo
>> Ok Laurent,
>> simple UML models.
>> bugzilla, attaching a zip with the two simple models, and the
>> correspondent diff models generated by the comparison.
>> Cheers,
>> Adolfo.
>>> Hi Adolfo,
>>> problem : could you send me the models you compare or the result of
>>> the comparison either here or via mail laurent (dot) goubet (at) obeo
>>> (dot) fr so that I can try and see why we detected a diff? As for the
>>> NPE, it should be fixed in the next build.
>>> Regards
>>> Laurent Goubet
>>> Obeo
>>>> BTW,
>>>> work neither.
>>>> Cheers,
>>>> Adolfo.
>>>>> Hi guys,
>>>>> have encountered some problems with it.
>>>>> an editor with the differences.
>>>>> try to compare the two same children of the root eObjects in both
>>>>> models, the compare editor is opened with 1 difference. Besides, if
>>>>> I explore the differences, a NPE is thrown.
>>>>> the editor.
>>>>> Cheers,
>>>>> Adolfo.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Method)
>>>>> Method)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: [EMF Compare] About MatchService API. [message #130574 is a reply to message #130559] |
Wed, 29 October 2008 11:13  |
--------------010601010609090702010602
Adolfo,
Bugzilla is indeed nice to keep track of all bugs ^^. We'll look into
this ASAP.
Laurent Goubet
Obeo
Adolfo S
Re: [EMF Compare] About MatchService API. [message #620372 is a reply to message #130478] |
BTW,
work neither.
Adolfo.
> Hi guys,
> options);
> editor.
> Cheers,
> Adolfo.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [EMF Compare] About MatchService API. [message #620374 is a reply to message #130491] |
Wed, 29 October 2008 09:24  |
--------------080402060001020800040808
Hi Adolfo,
Laurent Goubet
Obeo
Adolfo S
Re: [EMF Compare] About MatchService API. [message #620375 is a reply to message #130518] |
Ok Laurent,
simple UML models.
Adolfo.
> Hi Adolfo,
> Regards
> Laurent Goubet
> Obeo
>> BTW,
>> work neither.
>> Cheers,
>> Adolfo.
>>> Hi guys,
>>> the editor.
>>> Cheers,
>>> Adolfo.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: [EMF Compare] About MatchService API. [message #620376 is a reply to message #130531] |
Wed, 29 October 2008 10:55  |
--------------040904050207070703040901
Adolfo,
in the mails :).
Laurent Goubet
Obeo
Adolfo S
Re: [EMF Compare] About MatchService API. [message #620377 is a reply to message #130545] |
> Adolfo,
> in the mails :).
Adolfo.
> Laurent Goubet
> Obeo
>> Ok Laurent,
>> simple UML models.
>> Cheers,
>> Adolfo.
>>> Hi Adolfo,
>>> Regards
>>> Laurent Goubet
>>> Obeo
>>>> BTW,
>>>> work neither.
>>>> Cheers,
>>>> Adolfo.
>>>>> Hi guys,
>>>>> the editor.
>>>>> Cheers,
>>>>> Adolfo.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Method)
>>>>> Method)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: [EMF Compare] About MatchService API. [message #620378 is a reply to message #130559] |
Adolfo,
this ASAP.
Laurent Goubet
Obeo
Adolfo S
Current Time: Fri Jul 18 20:46:54 EDT 2025
Powered by FUDForum. Page generated in 0.05847 seconds
