Home » Archived » BIRT » How to generate Excel report using report engin.
How to generate Excel report using report engin. [message #112766] Sat, 21 January 2006 00:27 Go to next message
hi all,
I want to generate excel report using report engine. Now, iam able to
generate html/pdf reports. Can anyone suggest what is the api i have to
use to generate excel report.
Thanks in advance,
Bhaskar
Re: How to generate Excel report using report engin. [message #112829 is a reply to message #112766] Sat, 21 January 2006 18:13 Go to previous messageGo to next message
Ibhaskar wrote:
> hi all,
> Thanks in advance,
> Regards,
> Bhaskar
I don't think it is currently supported.
Re: How to generate Excel report using report engin. [message #112853 is a reply to message #112766] Sun, 22 January 2006 20:02 Go to previous messageGo to next message
bhaskar wrote:
> hi all,
> Thanks in advance,
> Regards,
> Bhaskar
you can use jasperreports api - birt don't support xls output
Re: How to generate Excel report using report engin. [message #113084 is a reply to message #112766] Mon, 23 January 2006 06:26 Go to previous messageGo to next message
Originally posted by: maspeli.deloitte.co.uk
One thing that we've found useful is to right-click on the HTML table
generated in IE or the in-eclipse preview (which is using the IE renderer)
and use the Export to Excel option. Charts can also be dragged over since
they are simply image files. It's obviously not the same as a full-blown
Excel export, but if you simply want to post-process a few things, it's
quite useful. Note that you can initiatite this sequence from the Excel side
too, using Get external data.
Martin
"bhaskar" <penbachi@rediffmail.com> wrote in message
news:c9bb219b07a3fe78a3082fa554683583$1@www.eclipse.org...
> hi all,
> Thanks in advance,
> Regards,
> Bhaskar
Re: How to generate Excel report using report engin. [message #113244 is a reply to message #112766] Mon, 23 January 2006 09:51 Go to previous messageGo to next message
Originally posted by: doug_porter.dailyaccess.nospam.com
You could use the CSV emitter that I believe is in the latest 2.0 builds. Not .xls files but Excel opens .csv by default.
Doug Porter
DailyAccess Corporation
"bhaskar" <penbachi@rediffmail.com> wrote in message news:c9bb219b07a3fe78a3082fa554683583$1@www.eclipse.org...
> hi all,
> Thanks in advance,
> Regards,
> Bhaskar
Re: How to generate Excel report using report engin. [message #130477 is a reply to message #112766] Wed, 15 February 2006 04:51 Go to previous message
You can export to csv file in interactive viewer.
??????:c9bb219b07a3fe78a3082fa554683583$1@www.eclipse.org...
> hi all,
> Thanks in advance,
> Regards,
> Bhaskar
Previous Topic:report variables
Next Topic:Reg : Displaying Date Filed In Correctlly
Current Time: Mon Nov 10 15:19:00 EST 2025
Powered by FUDForum. Page generated in 0.04728 seconds
