Calling refresh() on tableViewer clears the table data [message #1303905] |
Sat, 19 April 2014 10:50  |
I have a ViewerFilter on my TableViewer. When I set new filter data and call refresh on the TableViewer the table data is cleared and the select method of the ViewerFilter is not called. It works if I re-add the data back to the table viewer. I'm sure there is something very basic that I am missing. I've tried the following snippet in OSx and Windows.
Any advice is appreciated.
package org.eclipse.swt.snippets;
import org.eclipse.jface.viewers.ArrayContentProvider;
import org.eclipse.jface.viewers.CellLabelProvider;
import org.eclipse.jface.viewers.CheckboxTableViewer;
import org.eclipse.jface.viewers.ColumnPixelData;
import org.eclipse.jface.viewers.IStructuredContentProvider;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.TableLayout;
import org.eclipse.jface.viewers.TableViewerColumn;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.viewers.ViewerCell;
import org.eclipse.jface.viewers.ViewerComparator;
import org.eclipse.jface.viewers.ViewerFilter;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.events.KeyListener;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.Text;
public class SimpleTableExample {
private static int count = 20;
MyObject[] data = null;
CheckboxTableViewer tableViewer;
FileFilter fileFilter;
Text searchText;
public static void main( String[] args ) {
new SimpleTableExample();
public SimpleTableExample() {
Display display = new Display();
Shell shell = new Shell( display );
shell.setLayout( new GridLayout() );
searchText = new Text( shell, SWT.SEARCH | SWT.ICON_CANCEL | SWT.ICON_SEARCH );
GridData stData = new GridData( SWT.LEFT, SWT.CENTER, true, false );
stData.widthHint = 300;
searchText.setLayoutData( stData );
searchText.setMessage( "Filter Results" );
searchText.addKeyListener( new SearchKeyListener() );
Table table = new Table( shell, SWT.BORDER | SWT.MULTI | SWT.CHECK | SWT.V_SCROLL | SWT.H_SCROLL );
TableLayout tableLayout = new TableLayout();
table.setLayout( tableLayout );
tableViewer = new CheckboxTableViewer( table );
GridData data = new GridData( GridData.FILL_BOTH );
tableViewer.getTable().setLayoutData( data );
tableViewer.getTable().setLinesVisible( true );
tableViewer.getTable().setHeaderVisible( true );
TableViewerColumn column = new TableViewerColumn( tableViewer, SWT.NONE );
column.getColumn().setText( "Column 1" );
column.getColumn().setMoveable( true );
column.setLabelProvider( new MyLabelProvider() );
tableLayout.addColumnData( new ColumnPixelData( 400, true ) );
tableViewer.setContentProvider( ArrayContentProvider.getInstance() );
fileFilter = new FileFilter();
tableViewer.setFilters( new ViewerFilter[] { fileFilter } );
table.pack();
addData();
shell.pack();
shell.open();
while( !shell.isDisposed() ) {
if ( !display.readAndDispatch() )
display.sleep();
display.dispose();
private void addData() {
if (data == null) {
data = new MyObject[count];
for( int i = 0; i < count; i++ ) {
int r = 1 + (int) (Math.random() * ((50 - 1) + 1));
MyObject file = new MyObject( "File " + i, r );
data[i] = file;
for( int i = 0; i < data.length; i++ ) {
tableViewer.add( data[i] );
class MyObject {
private String name;
private Integer age;
public MyObject( String name, int age ) {
this.name = name;
this.age = age;
public String getName() {
return name;
public Integer getAge() {
return age;
private class MyLabelProvider extends CellLabelProvider implements ITableLabelProvider {
public Image getColumnImage( Object element, int columnIndex ) {
return null;
public String getColumnText( Object element, int columnIndex ) {
MyObject mo = (MyObject) element;
if ( columnIndex == 0 ) {
return mo.getName();
return mo.getAge().toString();
public void update( ViewerCell cell ) {
cell.setText( getColumnText( cell.getElement(), cell.getColumnIndex() ) );
class SearchKeyListener implements KeyListener {
public void keyPressed( KeyEvent e ) {
public void keyReleased( KeyEvent e ) {
String text = searchText.getText();
fileFilter.setSearchText( text );
public class FileFilter extends ViewerFilter {
private String searchString = ".*";
public void setSearchText( String s ) {
this.searchString = ".*" + s + ".*";
tableViewer.refresh();
// if I uncomment the following, everything works.
// addData();
public boolean select( Viewer viewer, Object parentElement, Object element ) {
if ( searchString == null || searchString.length() == 0 ) {
return true;
MyObject file = (MyObject) element;
if ( file.getName().matches( searchString ) ) {
return true;
return false;
Re: Calling refresh() on tableViewer clears the table data [message #1397306 is a reply to message #1397101] |
Wed, 09 July 2014 10:25  |
To add to what Hussein wrote, the javadocs for #add(Object) says:
* This method should be called (by the content provider) when a single
* element has been added to the model, in order to cause the viewer to
* accurately reflect the model. This method only affects the viewer, not
* the model. Note that there is another method for efficiently processing
* the simultaneous addition of multiple elements.
Brian.
FUDForum. Page generated in 0.24400 seconds
