Home » Archived » Test and Performance Tools Platform (TPTP) » AC on Linux (Ubuntu 8.04) symbol lookup error: ./../lib/libtptpUtils.so.4: undefined symbol: __ti3io
AC on Linux (Ubuntu 8.04) symbol lookup error: ./../lib/libtptpUtils.so.4: undefined symbol: __ti3io [message #130376] Thu, 22 May 2008 10:08 Go to next message
Originally posted by: dennis.brains2b.org
Dear all,
I'm running into a problem trying to start either IAC or AC on a Linux machie.
Starting it manually gives me the following error : symbol lookup error: ./../lib/libtptpUtils.so.4: undefined symbol: __ti3ios.
Versions:
Ubuntu 8.04 (Hardy)
Eclipse 3.3 (Europe)
Java 1.5.0_12
AC agent version 4.4 and 4.5 both give the same problem.
Can someone think of possible causes of this problem and/or solutions?
Thanks.
Dennis..
Re: AC on Linux (Ubuntu 8.04) symbol lookup error: ./../lib/libtptpUtils.so.4: undefined symbol: __t [message #130402 is a reply to message #130376] Fri, 23 May 2008 03:01 Go to previous messageGo to next message
dennis wrote at Thu, 22 May 2008 14:08:15 +0000:
> Dear all,
> machie. Starting it manually gives me the following error : symbol
> Versions:
> Ubuntu 8.04 (Hardy)
> Java 1.5.0_12
> Thanks.
> Dennis..
Hi Dennis,
please follow the below steps:
1, installing the necessary library:
$ sudo apt-get install libstdc++2.10-glibc2.2
2, setting some environment variables: (assume AC is installed at /opt/
tptpdc)
$ export PATH=$PATH:/opt/tptpdc/bin
$ export TEMP=/tmp
$ export LD_LIBRARY_PATH=/opt/tptpdc/lib
OK, you can run SetConfig.sh, and then run ACStart.sh to start the Agent
Controller.
-Richard.
Re: AC on Linux (Ubuntu 8.04) symbol lookup error: [message #131549 is a reply to message #130402] Mon, 23 June 2008 08:56 Go to previous message
>> Dear all,
>> Versions:
>> Ubuntu 8.04 (Hardy)
>> Java 1.5.0_12
>> Thanks.
>> Dennis..
>Hi Dennis,
>tptpdc)
>$ export TEMP=/tmp
>Controller.
>-Richard.
Dear Richard,
Sorry for the late reply, but I was away from my systems. The problem is that Hardy (Ubuntu 8.04) does not include
libstdc++2.10-glibc2.2 and I cannot find another library that includes the __ti3ios symbol.
Dennis
Previous Topic:Native dialogs: dead ends for GUI testing?
Next Topic:How to record Properties View values (Property <-> Value pair) ???
Current Time: Wed Jul 23 18:13:07 EDT 2025
Powered by FUDForum. Page generated in 0.03225 seconds
