Home » Modeling » Epsilon » [ECL module] Cannot determine stereotype property(Value field for stereotype property not available)
[ECL module] Cannot determine stereotype property [message #1299139] Wed, 16 April 2014 15:16 Go to next message
Hello Dimitris,
thanks for your last answer via email! I used that channel due to my problem with the Epsilon forum. Now I installed firefox and the forum works fine again Wink.
As already said in the email, I have the problem that I am not able to perform my ECL rules correctly, as I do not know how to compare my stereotype property values. I need to have something like "value", as in the EPackage registry, one can find e.g. "nameExpression" (however, I am not sure whether this the correct one - but it does not work anyway in the ECL program, as I tried).
In the following, please find my minimal example description.
Minimal example "[ECL module] Cannot determine stereotype property"
- The version of Epsilon that you're running:
Juno Service Release 2, Build id: 20130225-0426
- Instructions for reproducing the problem:
From the project attached in this message, perform the launch file "MinimalExampleForECLProblem.ecl.launch".
Have a look at the Console output, especially on the ordered sets, as here an appropriate property value for the stereotype properties "problem" and "context" is missing.
- A minimal version of all of the artefacts needed to reproduce the problem: models, metamodels (e.g. .ecore files),
See the artefacts contained in the project.
Epsilon programs (e.g. .eol, .evl, .egl files)
- Where applicable, Eclipse launch configurations or Ant build files for your Epsilon programs.
see launch file "MinimalExampleForECLProblem.ecl.launch".
- An Eclipse project containing the minimal artefacts (and launch configurations or Ant build files).
see attached zip file
Thanks a lot in advance and kind regards, Alexander
Re: [ECL module] Cannot determine stereotype property [message #1301503 is a reply to message #1299139] Fri, 18 April 2014 02:14 Go to previous messageGo to next message
Hi Alexander,
The attachment doesn't seem to have made it through I'm afraid.
Dimitris
Re: [ECL module] Cannot determine stereotype property [message #1301637 is a reply to message #1299139] Fri, 18 April 2014 03:59 Go to previous messageGo to next message
Good morning Dimitris,
sorry that the attachment was not there. After two further trials, I now have been able to upload it.
Thanks in advance and kind regards, Alexander
Re: [ECL module] Cannot determine stereotype property [message #1301705 is a reply to message #1301637] Fri, 18 April 2014 04:53 Go to previous messageGo to next message
Hi Alexander,
Your rule can be simplified as follows:
rule ProblemStatements
	match  l : Left!ProblemStatement
	with r: Right!ProblemStatement {
	compare : l.problem = r.problem and l.context = r.context
Dimitris
[Updated on: Thu, 28 January 2016 18:17] by Moderator
Re: [ECL module] Cannot determine stereotype property [message #1302546 is a reply to message #1301705] Fri, 18 April 2014 16:19 Go to previous message
Hi Dimitris,
thank you very much! Sometimes things are easier as supposed! I tried it and it works fine.
Happy Eastern and kind regards, Alexander
Previous Topic:containsKey not found?
Next Topic:Problems using HUTN with Epsilon
Current Time: Wed Jul 23 18:34:07 EDT 2025
Powered by FUDForum. Page generated in 0.04790 seconds
