Home » Archived » Test and Performance Tools Platform (TPTP) » Linux problems with clean "all in one" build
Linux problems with clean "all in one" build [message #130073] |
Wed, 14 May 2008 09:39  |
Running an Intel Core2 Duo machine with 32 bit Ubuntu 8 (heron). So EMT64
architecture, but 32 bit OS.
Linux rasputin 2.6.24-16-generic #1 SMP Thu Apr 10 13:23:42 UTC 2008 i686
GNU/Linux
Sun Java 1.5.0: -vm
/usr/lib/jvm/java-1.5.0-sun-1.5.0.15/jre/lib/i386/client/lib jvm.so
Downloaded this rev of all in one Eclipse-TPTP 4.4 :
http://www.eclipse.org/downloads/download.php?file=/tptp/4.4 .1/TPTP-4.4.1/tptp.runtime.allInOne.linux.gtk.x86-TPTP-4.4.1 .zip
The IAC starts and is listening, and I can telnet to it on 10002
successfully, etc: tcp 0 0 0.0.0.0:10002 0.0.0.0:*
LISTEN 19271/ACServer
The Profiling and Logging -> Hosts preferences shows localhost:10002 and
"test connection" works, says successful.
Yet, testing with a very simple HelloWorld java file with a main method
and nothing else results in the following error:
!MESSAGE A time-out occurred while attempting to launch the process
!STACK 1
org.eclipse.core.runtime.CoreException: A time-out occurred while
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:123)
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:131)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:597)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:513)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:313)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1163)
at
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
at java.lang.Thread.run(Thread.java:595)
I am using the "Java Profiling JRE 1.5 or newer" monitor in the profiling
run dialog (profile as->java application).
The agent controller directory in plugins has all the correct looking
stuff, LD_LIB path looks correct, etc (I have tried manual download,
update site download, followed many threads here, TEMP is defined, looked
at TimeCollector and has no .exe, looked at ipcrm, all over the map - read
documentation, etc).
Any help would be greatly appreciated.
Re: Linux problems with clean "all in one" build [message #130209 is a reply to message #130176] |
Sat, 17 May 2008 16:03  |
Originally posted by: me.myhouse.com
Alexander N. Alexeev wrote:
> Seems Integrated Agent controller has problems with configuration.
> Could you turn on debug log for AC and post it here.
> "INFORMATION" should be changed to DEBUG in the line <Logging
> directory="%TPTP_AC_HOME%\config" format="CBE" level="INFORMATION"/>
> file:
> eclipse\plugins\org.eclipse.tptp.platform.ac.linux_ia32<version >\agent_controller\config\serviceconfig.xml
> serviceconfig.xml file itself can be valuable too.
> Also I would suggest trying last stable build M7 for 4.5 release. It is
> available on TPTP download page.
> Thanks, Alex
Hi from someone having the same problem under Windows XP (SP2, 2Gig Ram,
120Gb Hdd) . I've never been able to profile anything other than a
trivial "hello world" application with the "Eclipse 3.3" version of
TPTP. The TPTP version that ran with eclipse 3.1 was fine, a bit fiddly
to install (IIRC no all in one package back then), bit it worked as
advertised. I skipped over Eclipse 3.2 and went straight to 3.3. Since
then, as I said, no profiling. I did the following test on a clean TPTP
all in one install:
> Eclipse SDK
> Version: 3.3.2
> Build id: M20080221-1800
I made the suggested change to my otherwise clean install to the
serviceconfig.xml (in my case in the
C:\eclipse.tptp\plugins\org.eclipse.tptp.platform.ac.win_ia3 2_4.4.1.v200802050100\agent_controller
directory), and here is the resulting log file:
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.437000Z" globalInstanceId="AE0A2E1FF4054D8CB21D35C9AEDB90D7" msg="createTransportListener (socket)" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 859" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="1812" componentType="Eclipse_TPTP"/>
> <situation categoryName="ReportSituation">
> <situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.453000Z" globalInstanceId="AA3C253E0EC2458084BC782308B7F682" msg="Successfully loaded transport layer: socketTL
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\ConnectionManager.c, line 184" instanceId="2" location="PM9300" locationType="IPV4" processId="1068" subComponent="Connection Manager" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.484000Z" globalInstanceId="AE78C8F41DA64F1D92CCE48F14D37FF7" msg="Successfully loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\ConnectionManager.c, line 235" instanceId="2" location="PM9300" locationType="IPV4" processId="1068" subComponent="Connection Manager" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.500000Z" globalInstanceId="A81FA3AC02084BFA8668954B23A62386" msg="createTransportListener (named pipe)." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 932" instanceId="1001" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.500000Z" globalInstanceId="A546F3ABDB9E401888BC9F15C85FD151" msg="Successfully loaded transport layer: namedPipeTL
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.500000Z" globalInstanceId="AB46241C45DD40A991F8D733C85CBB57" msg="Successfully loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.500000Z" globalInstanceId="AFFD1342AE5F463A87CFE0C0B5733F67" msg="createTransportListener (named pipe)." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 932" instanceId="1002" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.500000Z" globalInstanceId="A2D01236B9B9445685ED168B05931208" msg="Successfully loaded transport layer: namedPipeTL
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.500000Z" globalInstanceId="AF644E7E6105462EBD9BAE55A56F21D6" msg="Successfully loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.515000Z" globalInstanceId="A08348378CFE4025A5684034BD3A3E92" msg="createTransportListener (shared memory)." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\SRC\TRANSPORT\sharedMemTL\sharedMemListener.c, line 112" instanceId="1003" location="PM9300" locationType="IPV4" processId="1068" subComponent="Shared Memory TL" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.515000Z" globalInstanceId="AB0C2F8D26AA461286DFD6AB51991727" msg="Successfully loaded transport layer: sharedMemTL
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.515000Z" globalInstanceId="AB44B84BDB264918A274839FB893CE49" msg="Successfully loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:27.687000Z" globalInstanceId="AEB3B846188B46E2BC84B392D7EDAFB7" msg="Process polling thread created, tid = 592" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\TPTPClientCompTL\ClientCTL.c, line 982" instanceId="1004" location="PM9300" locationType="IPV4" processId="1068" subComponent="Client Compatibility TL" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.375000Z" globalInstanceId="A2CFA5899749478FB1913EB6053E5B8B" msg="Successfully loaded transport layer: tptpCCTL
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.375000Z" globalInstanceId="ACB227DDAB404BE2811B805AC9C63A8B" msg="Successfully loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.406000Z" globalInstanceId="A37290F66E974BEFBD3D895C380E814B" msg="ACTL process purge thread created, tid = 3712" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\TPTPAgentCompTL\Connect2AC.c, line 1365" instanceId="1005" location="PM9300" locationType="IPV4" processId="1068" subComponent="Agent Compatibility TL" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.406000Z" globalInstanceId="A802BC8FBA6143859EE530CE8B5BC685" msg="Successfully loaded transport layer: tptpACTL
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.406000Z" globalInstanceId="AC14BD8BF5AD40CBA2A1C406D8A94D62" msg="Successfully loaded command extractor: tptpCmdExtr" severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.406000Z" globalInstanceId="A7FA43A13A2A4E689D4329E5FD0C3A6C" msg="Ready to start servers" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\AgentController.c, line 190" instanceId="0" location="PM9300" locationType="IPV4" processId="1068" subComponent="Core" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.406000Z" globalInstanceId="ABC152A1B0D5468B8CBF2E80EB52560F" msg="startTransportListener (socket)" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 939" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.421000Z" globalInstanceId="A2316C9549554F4DADE7434958435DDA" msg="ConnectionManger - successfully added connectionID 100 for transportID 1004
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\ConnectionManager.c, line 328" instanceId="2" location="PM9300" locationType="IPV4" processId="1068" subComponent="Connection Manager" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.421000Z" globalInstanceId="AF16B921B19445B789F7D5E495027AF9" msg="Received command for unrecognized interface: iid=org.eclipse.tptp.eventProvider, cmd=listenerAccepted" severity="50" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\TPTPClientCompTL\Connect2AC.c, line 2238" instanceId="1004" location="PM9300" locationType="IPV4" processId="1068" subComponent="Client Compatibility TL" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.421000Z" globalInstanceId="A47AFD867536438188DB82317D4A7DD4" msg="Shared memory server is running and listening at "acbuffer" name." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\SRC\TRANSPORT\sharedMemTL\sharedMemListener.c, line 325" instanceId="1003" location="PM9300" locationType="IPV4" processId="1068" subComponent="Shared Memory TL" threadId="2584" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.421000Z" globalInstanceId="A65715E6C0A84D73BBA8184BC43F2FF9" msg="Named pipe server is running and listening at "\\.\pipe\IBMAC\acmasterlog" pipe." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 906" instanceId="1001" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="3740" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.421000Z" globalInstanceId="A2AB3419A7C845E0AB791C38F4C8EB0F" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 1090" instanceId="1001" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="3740" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.421000Z" globalInstanceId="AB2AFDE57EC347B0BC6BDB14588571A2" msg="Named pipe server is running and listening at "\\.\pipe\IBMAC\acmaster" pipe." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 906" instanceId="1002" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1420" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.421000Z" globalInstanceId="A71FA2E814D24CB1876687D4BBC2A711" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 1090" instanceId="1002" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1420" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.468000Z" globalInstanceId="A6041E3D571541D485BA0D98E519D122" msg="Socket server is running at port number of 10006." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 781" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="2172" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.468000Z" globalInstanceId="AFBB3C618A93467693BA8B3210739796" msg="Starting Process Controller:C:\eclipse.tptp\plugins\org.eclipse.tptp.platform .ac.win_ia32_4.4.1.v200802050100\agent_controller\bin\tptpPr ocessController.exe " severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\AgentManager.c, line 3095" instanceId="1" location="PM9300" locationType="IPV4" processId="1068" subComponent="Agent Manager" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.468000Z" globalInstanceId="AB16048664D745189C9B9C5A72EA484B" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\TPTPAgentCompTL\ACTLServer.c, line 449" instanceId="1005" location="PM9300" locationType="IPV4" processId="1068" subComponent="Agent Compatibility TL" threadId="1436" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.546000Z" globalInstanceId="A4D62CC16B064531B7238B4A0318FD77" msg="SUCCESSFULLY started Process Controller (pid=1440)" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\AgentManager.c, line 3120" instanceId="1" location="PM9300" locationType="IPV4" processId="1068" subComponent="Agent Manager" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.546000Z" globalInstanceId="A04D6B14342F444091127123EFD00130" msg="Everything is running" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\AgentController.c, line 204" instanceId="0" location="PM9300" locationType="IPV4" processId="1068" subComponent="Core" threadId="1812" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.859000Z" globalInstanceId="AE4D4B5D687A4366B3E979EDD6C6EA85" msg="ConnectionManger - successfully added connectionID 101 for transportID 1004
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\ConnectionManager.c, line 328" instanceId="2" location="PM9300" locationType="IPV4" processId="1068" subComponent="Connection Manager" threadId="252" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.859000Z" globalInstanceId="ABD1F830BAC4486C888735524B8EDE24" msg="Sent 40 bytes to client" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\TPTPClientCompTL\RACClientSupport.c, line 359" instanceId="1004" location="PM9300" locationType="IPV4" processId="1068" subComponent="Client Compatibility TL" threadId="252" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.968000Z" globalInstanceId="A2F3BB9178B1417C8F109CB6D018DC0C" msg="ConnectionManger - successfully added connectionID 102 for transportID 1004
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:28.968000Z" globalInstanceId="AD1FDC5344264FDA9459AC090A1AF370" msg="Sent 40 bytes to client" severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.078000Z" globalInstanceId="AF1267EFD44F4F749EE6920C6D8F5BA5" msg="Socket processClientRequest: Read 12 bytes." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 591" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="1124" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.078000Z" globalInstanceId="AB41FFB16E754D949BF8618C9B24A6F8" msg="Socket processRecdMsgs: Process msg from Control channel." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 477" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="1124" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.078000Z" globalInstanceId="A263B161814143038E3ABADEFCA7D801" msg="Socket: Read at least one complete message, process it." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 503" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="1124" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.078000Z" globalInstanceId="A54DD2C1C6594BE1A8D350BBAA9EF3B4" msg="Socket processRecdMsgs: Process msg from Control channel." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 519" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="1124" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.078000Z" globalInstanceId="A9414A09216D4E0C9BCCD03445F69ED6" msg="Socket: handle CONNECT request (Control channel)." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 188" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="1124" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.078000Z" globalInstanceId="A4725CC6278B40DA9C755A461A0B6021" msg="ConnectionManger - successfully added connectionID 103 for transportID 1000
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\ConnectionManager.c, line 328" instanceId="2" location="PM9300" locationType="IPV4" processId="1068" subComponent="Connection Manager" threadId="1124" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.078000Z" globalInstanceId="ACDE282465CC46BC85138CFB066F3B22" msg="Socket handleCONNECT: using Connection ID: 103" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\socketTL\socketListener.c, line 206" instanceId="1000" location="PM9300" locationType="IPV4" processId="1068" subComponent="Socket TL" threadId="1124" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.109000Z" globalInstanceId="A9166CF4EC1F4922BFAA67FB0155E954" msg="Received(49 bytes)." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 840" instanceId="1002" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1420" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.109000Z" globalInstanceId="A4BDEB4D222749079DA72A55A9DD7BEF" msg="Validated message of 49 bytes" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 756" instanceId="1002" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1420" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.109000Z" globalInstanceId="A90C26F2C1954960B7D2D06966D9F65E" msg="ConnectionManger - successfully added connectionID 104 for transportID 1002
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agentController\ConnectionManager.c, line 328" instanceId="2" location="PM9300" locationType="IPV4" processId="1068" subComponent="Connection Manager" threadId="1420" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.109000Z" globalInstanceId="AF24036A9F2C477285B4AC2BD6A9E17B" msg="NamedPipe getInitRequestDataBlock: returning Connection ID: 104." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 163" instanceId="1002" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1420" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.109000Z" globalInstanceId="A96D56C0F29F4C22B6CA60FC9904D5A0" msg="UUID: cc9bfc58-491f-497c-9da9-82d55ce2dd67." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 427" instanceId="1002" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1420" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.109000Z" globalInstanceId="A242E362C3D74380A1F9659093766B63" msg="NamedPipe: Sent 16 bytes on connection ID 104" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 222" instanceId="1002" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="1420" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.109000Z" globalInstanceId="AC2B9C062C8A4488BF79A2CCB82D2425" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.125000Z" globalInstanceId="A9848A7D1F724FF59784D56B93DEA78F" msg="Received(944 bytes)." severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 840" instanceId="1001" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="3740" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.125000Z" globalInstanceId="A0BDB14E51DB4C4EA8D0361C3A7C44B7" msg="Validated message of 944 bytes" severity="5" version="1.0.1">
> <sourceComponentId component="AgentController" componentIdType="TPTPComponent" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c, line 756" instanceId="1001" location="PM9300" locationType="IPV4" processId="1068" subComponent="Named Pipe TL" threadId="3740" componentType="Eclipse_TPTP"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.109000Z" globalInstanceId="AE8171E7DB4E4356A4F4C55876B0A0B8" msg="BaseAgent registerAgent: Agent (ProcessController) connected to AC " severity="5" version="1.0.1">
> <sourceComponentId component="ProcessController" componentIdType="TPTPComponent" componentType="Eclipse_TPTP" executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agents\agentBase\BaseAgentImpl.cpp, line 378" instanceId="104" location="PM9300" locationType="IPV4" processId="1440" subComponent="ProcessController" threadId="3536"/>
> <situationType reasoningScope="INTERNAL" reportCategory="LOG" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2008-05-17T19:44:29.125000Z" globalInstanceId="A2A33518F616410FB047EE50506185B6" msg="Ready to accept next named pipe request." severity="5" version="1.0.1">
> </situation>
> </CommonBaseEvent>
Current Time: Sat Jul 26 02:05:05 EDT 2025
Powered by FUDForum. Page generated in 0.26791 seconds
